What is Package Diagram?
Package diagram, a kind of structural diagram, shows the arrangement and organization of model elements in middle to large scale project. Package diagram can show both structure and dependencies between sub-systems or modules, showing different views of a system, for example, as multi-layered (aka multi-tiered) application - multi-layered application model.
Package Diagram Hierarchy
Learn UML Faster, Better and Easier
Are you looking for a Free UML tool for learning UML faster, easier and quicker? Visual Paradigm Community Edition is a UML software that supports all UML diagram types. It is an international award-winning UML modeler, and yet it is easy-to-use, intuitive & completely free.
Free Download
Purpose of Package Diagrams
Package diagrams are used to structure high level system elements. Packages are used for organizing large system which contains diagrams, documents and other key deliverables.
  • Package Diagram can be used to simplify complex class diagrams, it can group classes into packages.
  • A package is a collection of logically related UML elements.
  • Packages are depicted as file folders and can be used on any of the UML diagrams.
Package Diagram at a Glance
Package diagram is used to simplify complex class diagrams, you can group classes into packages. A package is a collection of logically related UML elements.
The diagram below is a business model in which the classes are grouped into packages:
  • Packages appear as rectangles with small tabs at the top.
  • The package name is on the tab or inside the rectangle.
  • The dotted arrows are dependencies.
  • One package depends on another if changes in the other could possibly force changes in the first.
Simple Package Diagram Example
Organize Complex Architectures with AI
Large-scale systems require clear boundaries and manageable modules. Visual Paradigm’s AI ecosystem simplifies the creation of Package Diagrams, helping you group related elements, define namespaces, and visualize critical import and access dependencies automatically.
AI-Powered Platforms
  • VP Desktop: Use integrated AI to organize existing model elements into a cohesive hierarchical package structure.
  • OpenDocs: Generate architectural documentation where Package Diagrams explain the high-level system layout.
  • AI Chatbot: Describe your system's modules to the AI Chat for an instant, layered dependency map.
Intelligent Structuring
🏗️ Automated Grouping: AI suggests logical clustering based on your problem description.
🔗 Dependency Mapping: Instantly visualize the relationships between subsystems.
Basic Concepts of Package Diagram
Package diagram follows hierarchal structure of nested packages. Atomic module for nested package are usually class diagrams. There are few constraints while using package diagrams, they are as follows.
  • Package name should not be the same for a system, however classes inside different packages could have the same name.
  • Packages can include whole diagrams, name of components alone or no components at all.
  • Fully qualified name of a package has the following syntax.
Package Syntax
Packages can be represented by the notations with some examples shown below:
Package Diagram Presentation
Package Diagram - Dependency Notation
There are two sub-types involved in dependency. They are <<import>> & <<access>>. Though there are two stereotypes users can use their own stereotype to represent the type of dependency between two packages.
Package Diagram Example - Import
<<import>> - one package imports the functionality of other package
Package Diagram Import
Package Diagram Example - Access
<<access>> - one package requires help from functions of other package.
Package Diagram Access
Modeling Complex Grouping
A package diagram is often used to describe the hierarchical relationships (groupings) between packages and other packages or objects. A package represents a namespace.
Package Diagram Example - Layering Structure
Package Diagram Layered Application
Package Diagram Example - Order Subsystem
Package Diagram Order Subsystem
Package Diagram Example - Order Processing System
Order Processing System - The Problem Description
We are going to design package diagram for "Track Order" scenario for an online shopping store. Track Order module is responsible for providing tracking information for the products ordered by customers. Customer types in the tracking serial number, Track Order modules refers the system and updates the current shipping status to the customer.
Based on the project Description we should first identify the packages in the system and then related them together according to the relationship:
Identify the packages of the system
  • There is a track order module, it has to talk with other module to know about the order details, let us call it "Order Details".
  • Next after fetching Order Details it has to know about shipping details, let us call that as "Shipping".
Package Diagram
Identify the dependencies in the System
  • Track order should get order details from "Order Details" and "Order Details" has to know the tracking info given by the customer. Two modules are accessing each other which suffices <<access>> dual dependency
    Package Diagram Dual Access
  • To know shipping information, "Shipping" can import "Track Order" to make the navigation easier.
    Package Diagram Use of import
  • Finally, Track Order dependency to UI Framework is also mapped which completes our Package Diagram for Order Processing subsystem.
    Order Processing Package Diagram
Try to Draw UML Package Diagram Now
You've learned what a Object Diagram is and how to draw a Object Diagram. It's time to draw a Object Diagram of your own. Get Visual Paradigm Community Edition, a free UML software, and create your own Object Diagram with the free Object Diagram tool. It's easy-to-use and intuitive.
Free Download
