šŸŽÆ Complete Tutorial: Drilling Down from C4 Container Diagram (Level 2) to Component Diagram (Level 3) in Visual Paradigm
A practical, step-by-step guide for architects and developers to evolve software architecture documentation using Visual Paradigm — comparing traditional modeling with AI-powered acceleration.
šŸš€ Introduction
Why Architecture Documentation Fails (And How to Fix It)
You’ve been there before: a new developer joins the team and spends weeks trying to understand how the system actually works. A critical bug surfaces, and the team struggles to trace where responsibilities lie across services. A stakeholder asks, “Where is the authentication logic handled?” and no one can give a clear, visual answer.
The problem isn’t a lack of documentation—it’s documentation that lives at the wrong level of abstraction.
High-level context diagrams are great for executives, but they don’t help developers navigate code. Detailed class diagrams are precise, but they overwhelm stakeholders and obscure the big picture. What’s missing is the middle layer: the component-level view that bridges strategic architecture with tactical implementation.
That’s where the C4 Model’s Component Diagram (Level 3) comes in—and where Visual Paradigm becomes your secret weapon.
What You’ll Learn in This Guide
This comprehensive tutorial shows you exactly how to:
āœ… Understand when and why to drill down from Container (L2) to Component (L3) diagrams
āœ… Prepare your Container diagram as a solid foundation for decomposition
āœ… Execute the drill-down workflow in Visual Paradigm using three distinct methods: traditional, manual, and AI-powered
āœ… Compare modeling approaches to choose the right tool for your team and context
āœ… Apply best practices that keep diagrams valuable, maintainable, and team-aligned
āœ… Learn from a complete, real-world example: an Online Banking API Application—with full PlantUML code you can reuse
Whether you’re a software architect designing a new system, a tech lead onboarding a distributed team, or a developer advocating for better documentation practices, this guide gives you the practical steps, tooling insights, and decision frameworks to make architecture visible, communicable, and actionable.
šŸ’” No theory without practice: Every concept is paired with concrete Visual Paradigm workflows, AI prompt examples, and copy-paste-ready PlantUML snippets.
Let’s turn architectural ambiguity into architectural clarity—starting with the container that matters most to your system today.
šŸ” Understanding the C4 Model Hierarchy
TheĀ C4 modelĀ (by Simon Brown) provides a layered approach to visualizing software architecture:
Level Name Audience Purpose
L1 System Context Business stakeholders, non-technical teams Show system boundaries and external dependencies
L2 Container Diagram Architects, tech leads, DevOps Show deployable units, technology choices, and high-level interactions
L3 Component Diagram Developers, architects, reviewers Reveal internal structure ofĀ one container — major building blocks and responsibilities
L4 Code/Class Diagram Developers Detailed implementation (optional, often auto-generated)
šŸŽÆĀ Key Insight: Component diagrams (L3) zoom intoĀ one container at a time. They areĀ notĀ full class diagrams — focus on significant, reusable components with clear responsibilities.
ā± When & Why to Drill Down to Component Level
āœ… Create Component Diagrams When:
  • A container isĀ complexĀ (e.g., monolithic backend, core microservice)
  • You need toĀ onboard new developersĀ or explain architecture to reviewers
  • You’re planningĀ refactoring, modularization, or technology migration
  • You want toĀ document architectural patternsĀ (MVC, Ports & Adapters, CQRS, etc.)
  • You need toĀ identify coupling, technical debt, or responsibility gaps
āŒ Skip Component Diagrams When:
  • The container is trivial (e.g., static file server, simple database)
  • The team already has strong shared understanding via code
  • Time/resources are limited and higher-level diagrams suffice
šŸ’”Ā Rule of Thumb: Start with yourĀ most business-critical or technically complex container. One well-crafted component diagram delivers more value than five shallow ones.
🧭 Preparation: Reviewing Your Container Diagram
Before drilling down, ensure yourĀ Container Diagram (L2)Ā is clear and complete:
āœ… Checklist:
  • Container has aĀ clear name,Ā technology stack, andĀ responsibility statement
  • KeyĀ external interactionsĀ are documented (who calls it? what does it call?)
  • Entry points are identified (e.g., REST APIs, message queues, CLI)
  • You’ve identifiedĀ internal structural candidates:
    • Controllers / API Endpoints
    • Business Services / Use Cases
    • Repositories / Data Access Layers
    • Integration Gateways / External Adapters
    • Domain Models / Entities
    • Caches, Validators, Configurators
šŸ”Ž Ask These Questions:
• Where is authentication/authorization handled?
• Where does core business logic live?
• How is data persisted or retrieved?
• Are there async processes or event publishers?
• Which components are stable vs. likely to change?
šŸ“Ā Pro Tip: Document architectural decisions in element properties or link to Architecture Decision Records (ADRs) for traceability.
šŸ”„ Drill-Down Workflow: Step-by-Step in Visual Paradigm
Step 1: Open Your Container Diagram
  • Launch Visual Paradigm → Open your project → Navigate to yourĀ C4 Container Diagram.
Step 2: Select Target Container for Decomposition
  • Identify the container to drill into (e.g., “API Application”, “Payment Service”).
  • Ensure it has clear boundaries and responsibilities defined.
Step 3: Create the Component Diagram (3 Methods)
🟢 Method A: Sub-Diagram Drill-Down (Recommended for Traceability)
  1. Right-click the targetĀ ContainerĀ element
  2. SelectĀ Create Sub-Diagram → C4 Component Diagram
  3. Visual Paradigm auto-creates:
    • A linked child diagram
    • The container as a boundary/context element
    • External relationships preserved (arrows pointing in)
āœ…Ā Best for: Maintaining hierarchy, traceability, and consistency across levels.
šŸ”µ Method B: Manual Creation (Full Control)
  1. Go toĀ Diagram > New > C4 > Component Diagram
  2. Name it clearly:Ā Component - [Container Name]
  3. Drag the relevantĀ ContainerĀ and external elements from Model Explorer
  4. Manually addĀ ComponentĀ shapes inside the container boundary
  5. Draw relationships with labels (protocol, purpose)
āœ…Ā Best for: Custom layouts, advanced styling, or when AI isn’t available.
🟣 Method C: AI-Powered Generation (Fastest for Prototyping)
  1. OpenĀ AI ChatbotĀ orĀ AI DiagramĀ feature in Visual Paradigm
  2. Use a structured prompt:
    Create a C4 Component diagram for the 'API Application' container
    (Java + Spring Boot). Include:
    - Banking Controller (Spring REST Controller)
    - Account Service, Transaction Service (Spring @Service)
    - Customer Repository (Spring Data JPA)
    - Notification Gateway (Java HTTP Client)
    - Domain Model (Java entities)
    Show: internal method calls, REST interactions with Web App,
    JDBC access to Database. Add responsibilities and technologies.
  3. Review, refine iteratively:
    • “Add async event publishing to Audit Log”
    • “Group components by layer: Presentation, Application, Infrastructure”
  4. Accept and customize the generated diagram
āœ…Ā Best for: Rapid prototyping, brainstorming, or teams new to C4 modeling.
Step 4: Build & Refine the Component Diagram
🧱 Add Components with Purpose
For each component, define:
  • Name: Clear, responsibility-focused (e.g., “Payment Validator”, not “Utils”)
  • TechnologyĀ (optional but recommended): e.g., “Spring @Service”, “Kafka Producer”
  • Responsibility: 1-sentence description of what it does
šŸ”— Define Relationships
  • Use directional arrows withĀ labels:
    • Calls via internal method
    • Publishes event to
    • Reads from / Writes to
    • Validates using
  • IncludeĀ protocol/technologyĀ where helpful:Ā gRPC,Ā JPA,Ā Async REST
🌐 Preserve External Context
  • Show howĀ other containers or personsĀ interact with entry-point components
  • Example:Ā Web App → Banking Controller: POST /api/accounts (JSON/HTTPS)
šŸŽØ Layout & Styling Tips
  • PlaceĀ entry-point componentsĀ (controllers) near container boundary
  • Group related components visually (use frames or color coding)
  • Minimize crossing lines; use orthogonal routing
  • Add aĀ legendĀ explaining notation, colors, or stereotypes
Step 5: Validate & Iterate
  • Walkthrough with team: Does this match the codebase? Are responsibilities clear?
  • Check for smells: God components, circular dependencies, missing abstractions
  • Avoid over-detailing: Move fine-grained classes to Code (L4) diagrams
  • Export & share: PDF, PNG, or embed in Confluence/Notion via VP integration
  • Treat as living documentation: Update as architecture evolves
āš™ļø Traditional vs. AI-Powered Modeling in Visual Paradigm
Feature Traditional Modeling AI-Powered Modeling
Speed Manual, deliberate (30–90 mins) Rapid prototyping (5–15 mins)
Control Full control over every element Requires prompt engineering & refinement
Learning Curve Steeper (requires C4 + VP knowledge) Lower (natural language input)
Consistency High (if model repository used) Variable (depends on prompt quality)
Best For Final documentation, regulated environments Brainstorming, onboarding, early design
Traceability Excellent (sub-diagram linking) Good (if generated from model elements)
Collaboration Real-time editing, comments AI suggestions can spark team discussion
šŸ¤– AI Prompt Engineering Tips for Better Results
āœ… DO:
• Be specific about container tech stack and responsibilities
• List expected component names/types upfront
• Specify interaction styles (sync/async, protocol)
• Request responsibilities and technology annotations
• Iterate: "Now add caching layer between Service and Repository"
āŒ AVOID:
• Vague prompts: "Make a component diagram"
• Overloading: Asking for 20+ components in one go
• Ignoring context: Not mentioning external dependencies
• Expecting perfection: Always review and refine AI output
šŸ”— Hybrid Approach (Recommended)
  1. UseĀ AI to generate a first draftĀ quickly
  2. Refine manuallyĀ in Visual Paradigm for accuracy and styling
  3. Link as sub-diagramĀ to maintain hierarchy
  4. Export to PlantUMLĀ for version-controlled “diagrams as code” workflows
šŸŽ Benefits: Who Should Use This & When
šŸ‘„ Target Audiences
Role Why They Benefit
Software Architects Clarify modular boundaries, validate patterns, communicate vision
Tech Leads / Senior Devs Onboard team members, guide refactoring, review PRs against architecture
Developers Understand where to add features, avoid coupling, navigate codebase
Engineering Managers Assess technical debt, plan team structure, estimate effort
Reviewers / Auditors Verify separation of concerns, security boundaries, compliance
Product Owners Understand technical constraints impacting feature delivery
šŸš€ Key Benefits
Benefit Impact
Clarity of Responsibilities Reduces ambiguity about “who does what” in the codebase
Improved Onboarding New hires understand architecture in hours, not weeks
Better Refactoring Decisions Visualize coupling before making structural changes
Living Documentation Diagrams stay relevant when linked to model repository
Stakeholder Alignment Bridge gap between high-level context and implementation
Technical Debt Visibility Spot God components, tight coupling, or missing abstractions
šŸ“… When to Invest Time
  • āœ… Starting a new complex module or microservice
  • āœ… Preparing for architecture review or compliance audit
  • āœ… Onboarding a distributed or new team
  • āœ… Planning major refactoring or technology migration
  • āœ… Documenting legacy systems for knowledge preservation
šŸ›” Best Practices & Common Pitfalls
āœ… Best Practices
  1. One container per diagram — keep scope focused
  2. 5–12 components max — if more, consider splitting concerns
  3. Use consistent namingĀ across C4 levels (traceability!)
  4. Add responsibilities, not just names — “what” + “why”
  5. Show external context — how do other systems interact?
  6. Link to code — use VP’s model repository or export to PlantUML
  7. Review with team — treat diagrams as collaborative artifacts
  8. Update iteratively — schedule diagram reviews with sprint retros
āŒ Common Pitfalls to Avoid
Pitfall Consequence Solution
Turning L3 into a class diagram Overwhelming detail, hard to maintain Focus on components, not classes
Creating diagrams for trivial containers Wasted effort, diagram fatigue Only decompose valuable/complex containers
Losing external context Isolated view, misses integration points Always show entry-point interactions
Inconsistent naming across levels Confusion, broken traceability Use model repository, reuse elements
Overloading with relationships Visual clutter, unreadable Show key interactions only; use notes for details
Treating diagrams as “one-and-done” Outdated docs, loss of trust Schedule updates; integrate with CI/CD if possible
šŸ’¼ Example: Online Banking API Application
šŸ“ Container Diagram (Level 2) — PlantUML Code
Here’s the complete PlantUML code and the Container Diagam showing the high-level architecture:
@startuml
!include https://raw.githubusercontent.com/plantuml-stdlib/C4-PlantUML/master/C4_Container.puml
Person(customer, "Customer", "Uses internet banking")
System_Boundary(c4, "Internet Banking System") {
    Container(web, "Web Application", "React + TypeScript", "Delivers static content and interacts with API")
    Container(api, "API Application", "Java + Spring Boot", "Provides business logic and data access via REST/JSON")
    ContainerDb(db, "Customer Database", "PostgreSQL", "Stores customer and account data")
Rel(customer, web, "Uses", "HTTPS")
Rel(web, api, "Makes API calls", "JSON/HTTPS")
Rel(api, db, "Reads from / Writes to", "JDBC")
@enduml
What this shows:
  • Person: Customer using the banking system
  • Containers:
    • Web Application (React frontend)
    • API Application (Spring Boot backend)
    • Customer Database (PostgreSQL)
  • Relationships: HTTPS from customer to web, JSON/HTTPS from web to API, JDBC from API to database
This is yourĀ Level 2 diagram — the starting point before drilling down.
šŸ”¬ Component Diagram (Level 3) — PlantUML Code
Now, let’s drill down into theĀ “API Application” container. Here’s the complete PlantUML code and the Diagram:
@startuml
!include https://raw.githubusercontent.com/plantuml-stdlib/C4-PlantUML/master/C4_Component.puml
title Component Diagram for API Application
Container(api, "API Application", "Java + Spring Boot")
' Components inside the container
Component(controller, "Banking Controller", "Spring REST Controller", "Handles incoming REST requests for accounts and transactions")
Component(accountService, "Account Service", "Spring @Service", "Orchestrates account-related business logic")
Component(transactionService, "Transaction Service", "Spring @Service", "Handles transaction processing and validation")
Component(repository, "Customer Repository", "Spring Data JPA", "Provides CRUD access to the database")
Component(gateway, "Notification Gateway", "Java HTTP Client", "Sends notifications via external email/SMS service")
Component(domain, "Domain Model", "Java Classes", "Contains Account, Transaction, and Customer entities with business rules")
' Internal relationships
Rel(controller, accountService, "Delegates to", "")
Rel(controller, transactionService, "Delegates to", "")
Rel(accountService, repository, "Uses", "JPA")
Rel(transactionService, repository, "Uses", "JPA")
Rel(transactionService, gateway, "Sends via", "Async")
Rel(accountService, domain, "Operates on", "")
Rel(transactionService, domain, "Operates on", "")
' External context (from other containers)
Container_Ext(web, "Web Application", "React", "Calls the API")
Rel(web, controller, "Sends requests to", "JSON/HTTPS")
SHOW_LEGEND(true)
@enduml
What this shows:
🧱 Components Inside API Container:
Component Technology Responsibility
Banking Controller Spring REST Controller Handles incoming REST requests for accounts and transactions
Account Service Spring @Service Orchestrates account-related business logic
Transaction Service Spring @Service Handles transaction processing and validation
Customer Repository Spring Data JPA Provides CRUD access to the database
Notification Gateway Java HTTP Client Sends notifications via external email/SMS service
Domain Model Java Classes Contains Account, Transaction, and Customer entities with business rules
šŸ”— Key Relationships:
Web App → Banking Controller: Sends requests to (JSON/HTTPS)
Banking Controller → Account Service: Delegates to
Banking Controller → Transaction Service: Delegates to
Account Service → Customer Repository: Uses (JPA)
Transaction Service → Customer Repository: Uses (JPA)
Transaction Service → Notification Gateway: Sends via (Async)
Account Service → Domain Model: Operates on
Transaction Service → Domain Model: Operates on
šŸŽØ Architecture Patterns Visible:
  • Layered Architecture: Controller → Service → Repository → Database
  • Separation of Concerns: Business logic (Services) separated from data access (Repository)
  • Domain-Driven Design: Explicit Domain Model component
  • External Integration: Notification Gateway for async communications
šŸ”„ Visual Paradigm Implementation
InĀ Visual Paradigm, this same diagram would be created with:
  1. Container boundary: The “API Application” shown as a frame/boundary element
  2. Component shapes: Each component with:
    • Name (e.g., “Banking Controller”)
    • Technology stereotype (e.g., “Spring REST Controller”)
    • Description (e.g., “Handles incoming REST requests…”)
  3. Relationships:
    • Solid arrows for synchronous calls
    • Dashed arrows for async operations
    • Labels showing protocol/technology
  4. External context: The “Web Application” container shown outside the boundary with a relationship to the Banking Controller
  5. Legend: Automatically generated showing notation meanings
šŸ”„Ā Traceability: In Visual Paradigm, double-clicking the “API Application” container in the Level 2 diagram automatically navigates to this Level 3 component diagram.
šŸ“Š Comparing PlantUML vs. Visual Paradigm
Aspect PlantUML Code Visual Paradigm GUI
Creation Text-based, version-controlled Drag-and-drop, visual
Learning Curve Requires PlantUML syntax Intuitive for visual modelers
Collaboration Git-friendly, code reviews Real-time editing, comments
AI Support Limited Built-in AI diagram generation
Traceability Manual linking Automatic sub-diagram navigation
Export Options PNG, SVG, PDF PNG, SVG, PDF, Word, HTML
Best For DevOps, “diagrams as code” Enterprise architects, teams
Hybrid Workflow:
  1. Generate initial diagram usingĀ Visual Paradigm AI
  2. Export toĀ PlantUMLĀ for version control
  3. Refine inĀ Visual ParadigmĀ for stakeholder presentations
  4. Store PlantUML inĀ GitĀ for developer access
āœ… Getting Started Checklist
šŸš€ Before You Start
  • Container diagram (L2) is complete and reviewed
  • Target container is selected (complex, critical, or unclear)
  • Team agrees on component naming conventions
  • Visual Paradigm project is set up with C4 stencil library
šŸ›  During Modeling
  • Use sub-diagram feature for traceability (or AI for speed)
  • Add components with name + technology + responsibility
  • Label relationships with purpose and protocol
  • Preserve external context (who calls this?)
  • Apply clean layout: minimize crossings, group logically
  • Add legend and brief documentation notes
šŸ” After Creation
  • Walk through with development team for validation
  • Export to PDF/PNG and share in team wiki (Confluence/Notion)
  • Link diagram to ADRs or code repositories if possible
  • Schedule quarterly review to keep documentation fresh
  • Consider exporting to PlantUML for version control
šŸ”„ Continuous Improvement
  • Gather feedback: “Did this diagram help you understand the system?”
  • Track usage: Which diagrams are referenced most in PRs/docs?
  • Iterate prompts if using AI: Save successful templates
  • Train team: Share this tutorial internally for consistency
Drilling down fromĀ Container (L2)Ā toĀ Component (L3)Ā diagrams in the C4 model is a powerful practice for making software architectureĀ visible, communicable, and maintainable.
Visual ParadigmĀ accelerates this process through:
  • āœ…Ā Traditional modeling: Precise, traceable, enterprise-ready
  • āœ…Ā AI-powered generation: Fast, iterative, great for prototyping
  • āœ…Ā PlantUML integration: Version-controlled “diagrams as code”
  • āœ…Ā Hybrid workflows: Best of both worlds for modern teams
šŸŽÆĀ Start small: Pick one critical container. Create its component diagram. Validate with your team. Iterate.
When done well, component diagrams becomeĀ living artifactsĀ that reduce onboarding time, improve architectural decisions, and serve as a single source of truth throughout the software delivery lifecycle.
šŸ“ŒĀ Next Steps:
    1. Open your Visual Paradigm project today
    2. Select your most complex container
    3. Try the AI prompt:Ā “Create a C4 Component diagram for [Container] with 5–7 key components, showing responsibilities and interactions”
    4. Refine, validate, and share with your team
  1. Export to PlantUML for version control
šŸ Conclusion
From Diagrams to Decisions: Making Architecture Work for Your Team
Software architecture isn’t about creating perfect diagrams—it’s about enabling better decisions, faster collaboration, and more resilient systems. The journey from Container (Level 2) to Component (Level 3) diagrams in the C4 model isn’t just a modeling exercise; it’s a strategic practice that transforms how your team understands, builds, and evolves software.
Key Takeaways
šŸ”¹ Focus creates clarity: Component diagrams shine when you decompose one critical container at a time—not every deployable unit needs this level of detail.
šŸ”¹ Traceability matters: Using Visual Paradigm’s sub-diagram linking ensures your architecture stays coherent across levels, reducing confusion and rework.
šŸ”¹ AI accelerates, humans refine: Leverage Visual Paradigm’s AI features to generate first drafts rapidly, then apply human judgment to validate responsibilities, interactions, and architectural intent.
šŸ”¹ Living documentation wins: Treat diagrams as collaborative, evolving artifacts—not one-time deliverables. Review them in sprint retros, link them to ADRs, and keep them synchronized with code.
šŸ”¹ PlantUML bridges worlds: Export your Visual Paradigm models to PlantUML for version control, code reviews, and “diagrams as code” workflows that developers love.
Your Next Move
Don’t wait for the “perfect time” to improve your architecture documentation. Start small, start today:
1ļøāƒ£ Pick one container in your system that feels complex, unclear, or critical
2ļøāƒ£ Open Visual Paradigm and try the AI prompt:
“Create a C4 Component diagram for [Container Name] with 5–7 key components, showing responsibilities, technologies, and interactions”
3ļøāƒ£ Refine with your team in a 30-minute walkthrough: “Does this match how the code actually works?”
4ļøāƒ£ Export and share: Publish to your team wiki, link to your backlog, or commit the PlantUML to your repo
5ļøāƒ£ Repeat: Add one component diagram per sprint. Watch onboarding time drop and architectural confidence rise.
Final Thought
“The best architecture documentation doesn’t describe what the system is—it enables people to build what the system should become.”
Component diagrams, done well, do exactly that. They turn abstract architecture into shared understanding. They help new engineers contribute faster. They give reviewers confidence. They make refactoring less risky. And with Visual Paradigm—whether you prefer traditional precision or AI-powered speed—you have the tools to make it happen.
Your architecture is a conversation. Make it visual. Make it clear. Make it matter.
šŸ—ļøāœØ Now go build something great—and document it so others can too.
šŸ”— Continue Learning:
Architecture is a conversation. Component diagrams help you have that conversation — clearly, consistently, and collaboratively.Ā šŸ—ļøāœØ
