C4 Container Diagram: A Practical Guide for Beginners
Introduction: Why the Container Diagram is Your Next Important Step
The Context Diagram gave you the “who” and “what.” The Container Diagram gives you the “how” and “where.” It’s the sweet spot in the C4 model where technical reality meets architectural clarity.
At this level, you stop talking in business abstractions and start mapping the actual deployable units that make your system run. You’ll bridge the gap between product stakeholders (who need to understand data flow and dependencies) and engineering teams (who need to know tech stacks, boundaries, and integration points). After reading this guide, you’ll be able to draft, review, and maintain a Container Diagram that accelerates onboarding, clarifies architecture decisions, and prevents costly misalignments.
What is a C4 Container Diagram? Simple Explanation
In the C4 model, a Container Diagram is Level 2. It zooms one level deeper than the Context Diagram by breaking your single “System in Scope” into its independently runnable or deployable pieces.
What “Container” actually means in C4:
A container is any application or data store that runs in its own process space. It is not necessarily a Docker container. It’s a logical runtime boundary. Examples: a web application, a mobile app, a backend API, a relational database, a message queue, or a file storage service.
How it differs from the Context Diagram (Level 1):
Context Diagram (Level 1) Container Diagram (Level 2)
Shows 1 system in scope Breaks that system into multiple containers
Focuses on people & external systems Focuses on technical building blocks
No technology details Explicitly shows tech choices (e.g., React, PostgreSQL, Kafka)
For stakeholders & product teams For developers, architects, DevOps, and tech leads
Who should use it and when:
Engineering teams during system design, architecture reviews, incident post-mortems, and developer onboarding. Use it when you’re ready to decide tech stacks, plan deployments, or clarify data flow. Skip it if you’re still in early ideation or if the system is a single monolith with no external dependencies.
Understanding Containers – The Core Concept
What counts as a Container?
  • Applications: Web apps, mobile apps, SPAs, serverless functions, CLI tools
  • Data Stores: SQL databases, NoSQL databases, object storage, caches
  • Messaging/Integration: Message brokers, event streams, API gateways
  • External Services: (Carried over from Context) Payment gateways, SSO, third-party APIs
Logical vs Deployable Containers
  • Logical: How the system is conceptually split (e.g., “User Service,” “Reporting Engine”)
  • Deployable: How it actually runs in production (e.g., “user-service.jar,” “reporting-db-aurora”)
    Best practice: Align logical and deployable boundaries whenever possible. If they diverge, note it in documentation.
Real-life examples of containers
  • Customer Web App (React/TypeScript)
  • Order API (Java/Spring Boot)
  • PostgreSQL Database
  • Redis Cache
  • RabbitMQ Message Broker
Common beginner confusion & how to avoid it
  • “Is a Docker container a C4 container?” → Only if it represents a distinct runtime unit. A single Docker container hosting a monolith is still just 1 C4 container.
  • ❌ “Should I show load balancers or Kubernetes pods?” → No. Those are infrastructure/deployment concerns. C4 focuses on software architecture, not topology.
  • ✅ Fix: Stick to independently deployable/runnable software units. Keep infrastructure for deployment diagrams or runbooks.
Purpose and Benefits of the Container Diagram
What this diagram helps you achieve
  • Visualize tech stack decisions in context
  • Clarify data flow and integration patterns
  • Identify single points of failure or tight couplings
  • Align developers, DevOps, and architects on boundaries
Key questions it answers
  1. What technologies are we using and where?
  2. How do containers communicate? (Sync vs async, protocols)
  3. Where is data stored and how is it accessed?
  4. What external systems are we tightly coupled to?
How it improves communication
Developers get a clear map of dependencies. Architects can spot anti-patterns early. Stakeholders understand where data lives and how features are technically delivered. It becomes the single source of truth for technical onboarding.
When you should (and shouldn’t) create one
  • ✅ Do: When designing a new system, refactoring a monolith, onboarding new engineers, or planning cloud migration.
  • ❌ Don’t: For trivial scripts, during early brainstorming, or when you’re already deep in component-level design (jump to Level 3 instead).
Key Elements of a C4 Container Diagram
Element Representation Purpose
System Boundary Dashed rectangle around containers Groups all containers belonging to your system
Containers Solid rectangles with tech tags Independent runtime units (apps, DBs, queues)
Users Person icons (optional) Retains context from Level 1
External Systems Different color/style Third-party services your containers talk to
Relationships Directed arrows with labels + tech Data flow, sync/async, protocol (e.g., HTTPS, JDBC, AMQP)
Technology Tags Inside or below container boxes Explicit stack choices (critical at this level)
Step-by-Step: How to Create Your First Container Diagram
Step 1: Start from your Context Diagram
Keep your Level 1 diagram open. You’ll reuse the same users and external systems. Your single “System” box is now a boundary you’ll fill with containers.
Step 2: Break the system into containers
Ask: “What runs independently?” List web apps, APIs, databases, caches, queues. Keep it to 5–9 containers max.
Step 3: Add users and external systems
Place users on the left, external systems on the right. Keep the same names from your Context Diagram for consistency.
Step 4: Define relationships and technology
Draw arrows between containers. Label them with what flows + protocol. Add tech tags to every container (e.g., Node.js, MongoDB, gRPC).
Step 5: Add clear labels and legends
Use a consistent naming pattern: [Purpose] ([Technology]). Add a legend if you use custom colors or line styles.
Beginner Checklist:
  • All containers have explicit technology tags
  • No component/class details leaked in
  • Arrows labeled with data/protocol
  • External systems clearly distinguished
  • Readable by a mid-level engineer in 60 seconds
Real-World Examples for Beginners
1. Simple Web Application + Database
@startuml
!include https://raw.githubusercontent.com/plantuml-stdlib/C4-PlantUML/master/C4_Container.puml
title C4 Container Diagram - Blog Platform
Person(user, "Reader", "Views and comments on blog posts")
System_Ext(cdn, "CDN Provider", "Delivers static assets globally")
Container_Boundary(blog_system, "Blog Platform") {
    Container(web_app, "Web Application", "React, TypeScript", "Serves UI, handles routing & state")
    Container(api, "Blog API", "Node.js, Express", "CRUD operations, auth, comment moderation")
    ContainerDb(db, "PostgreSQL", "Relational Database", "Stores posts, users, comments")
    Container(cache, "Redis Cache", "In-memory Store", "Session storage & hot post caching")
Rel(user, web_app, "Views pages", "HTTPS")
Rel(web_app, api, "Fetches data", "HTTPS/REST")
Rel(api, db, "Reads/Writes data", "JDBC")
Rel(api, cache, "Caches sessions", "TCP")
Rel(web_app, cdn, "Loads assets", "HTTPS")
@enduml
2. Mobile App + Backend API + Cloud Services
@startuml
title C4 Container Diagram - Task Manager Mobile App
Person(user, "Mobile User", "Creates and tracks daily tasks")
Container_Boundary(task_system, "Task Manager System") {
    Container(mobile_app, "iOS/Android App", "Swift, Kotlin", "Offline-first UI, local sync")
    Container(api_gateway, "API Gateway", "AWS API Gateway", "Route & throttle requests")
    Container(task_service, "Task Service", "Python, FastAPI", "Business logic, CRUD")
    ContainerDb(dynamo, "DynamoDB", "NoSQL Database", "Stores tasks & user profiles")
    ContainerQueue(queue, "SQS Queue", "Message Queue", "Async notification jobs")
    Container(notifier, "Notification Worker", "Node.js", "Sends push/email alerts")
System_Ext(apns, "Apple Push Service", "iOS notifications")
System_Ext(fcm, "Firebase Cloud Messaging", "Android notifications")
Rel(user, mobile_app, "Creates tasks", "HTTPS")
Rel(mobile_app, api_gateway, "Syncs data", "HTTPS")
Rel(api_gateway, task_service, "Routes requests", "HTTPS")
Rel(task_service, dynamo, "Persists tasks", "AWS SDK")
Rel(task_service, queue, "Enqueues alerts", "AWS SDK")
Rel(queue, notifier, "Triggers worker", "AMQP")
Rel(notifier, apns, "Sends iOS push", "HTTPS")
Rel(notifier, fcm, "Sends Android push", "HTTPS")
@enduml
3. Microservices Example
@startuml
title C4 Container Diagram - E-Commerce Microservices
Person(customer, "Customer", "Shops and tracks orders")
Container_Boundary(ecommerce, "E-Commerce Platform") {
    Container(frontend, "Web Frontend", "Next.js", "Product browsing & checkout UI")
    Container(order_svc, "Order Service", "Java, Spring Boot", "Order lifecycle management")
    Container(inventory_svc, "Inventory Service", "Go", "Stock tracking & reservations")
    ContainerDb(order_db, "Order DB", "PostgreSQL", "Order & payment records")
    ContainerDb(inv_db, "Inventory DB", "MongoDB", "Product stock data")
    ContainerQueue(events, "Event Stream", "Apache Kafka", "Cross-service async events")
System_Ext(payment, "Stripe API", "Payment processing")
Rel(customer, frontend, "Places orders", "HTTPS")
Rel(frontend, order_svc, "Submits checkout", "gRPC")
Rel(order_svc, order_db, "Stores orders", "JDBC")
Rel(order_svc, events, "Publishes OrderCreated", "Kafka")
Rel(events, inventory_svc, "Consumes events", "Kafka")
Rel(inventory_svc, inv_db, "Updates stock", "Mongo Driver")
Rel(order_svc, payment, "Charges card", "HTTPS/REST")
@enduml
Before vs After: Poor diagram vs Clear Container Diagram
Poor: Boxes labeled Service1, DB, Queue with no tech tags, arrows labeled calls, uses, or missing entirely. Component details (classes, packages) mixed in.
Clear: [Purpose] ([Tech]) naming, explicit protocols on arrows, logical grouping, zero implementation leakage, readable data flow direction.
Best Practices for Clean & Effective Container Diagrams
  • Layout tips: Place users left, externals right. Group related containers vertically or in bounded zones. Use auto-layout tools to reduce crossing lines.
  • Naming conventions: [Business Function] ([Technology]). Example: User Auth Service (Node.js), Analytics DB (ClickHouse).
  • How much detail is enough? Stop at independently deployable units. If you’re drawing internal modules, packages, or classes, you’ve crossed into Level 3 (Component Diagram).
  • Colors & styling: Use Visual Paradigm’s built-in C4 theme. Keep containers in one palette, externals in another, and databases/queues in distinct but harmonious shades. Add a legend only if deviating from defaults.
Creating Container Diagrams with Visual Paradigm
Why Visual Paradigm works great for beginners
  • Native C4 Model diagram type with dedicated stencils
  • Built-in relationship routing, alignment, and theme presets
  • Tech tag fields built into container properties
  • Seamless export, versioning, and team sharing (Desktop & Online)
Traditional Method: Manual creation in Visual Paradigm
  1. Create a new project: Select Project > New from the main menu. Enter the project name and click Create Blank Project.
  2. Create a Container diagram: Select Diagram > New. In the New Diagram window, select C4 Container Diagram.
  3. Drag Container from the palette.
  4. Draw System Boundary around your containers.
  5. Use Relationship connectors; double-click to add labels & protocol
  6. Right-click containers → Open Specification → Fill Technology field
AI-Powered Method: Let AI generate your Container Diagram
  1. Open AI Diagram Generator (Tools > AI Diagram Generator). Select C4 Model to be the diagram type, Containers to be the diagram.
  2. Prompt: Create a C4 Container Diagram for a task management app. Containers: Mobile App (Swift/Kotlin), API Gateway, Task Service (Python), DynamoDB, SQS, Notification Worker. External: APNS, FCM. Show data flow and protocols.
  3. Review generated layout, adjust tech tags, refine arrow labels
Traditional vs AI-Assisted: Pros, Cons & When to Use Each
Aspect Traditional Manual AI-Assisted
Control High precision, custom styling Fast baseline, requires tuning
Learning Teaches C4 structure deeply Accelerates drafting, needs verification
Best For Complex domains, strict governance Rapid prototyping, team alignment
Tech Tags Manually added via properties Often auto-inferred, always verify
Hands-On Tutorial: Building a Container Diagram in Visual Paradigm
Setting up your C4 project
  1. Open Visual Paradigm Desktop
  2. Launch Visual Paradigm. Select Project New from the main menu.
  3. Name it System_Containers_v1. Click Create Blank Project to confirm.
  4. Select Diagram > New from the main menu.
  5. In the New Diagram window, select C4 Container Diagram.
Traditional step-by-step guide
  1. Drag a System Boundary shape. Rename it to your system name.
  2. Inside, place 3–5 Container shapes.
  3. Place  System_Ext right.
  4. Connect with Relationship arrows. Double-click each arrow → add label + protocol.
  5. Select each container → Open Specification panel → fill Technology field.
Using Visual Paradigm AI to auto-generate the diagram
  1. Open Tools > AI Diagram Generator
  2. Paste a structured prompt (see examples above)
  3. Click OK. VP places shapes, draws arrows, and applies C4 styling.
How to review, refine, and improve the AI output
  • Replace vague labels (sends data) with precise ones (publishes order events via Kafka)
  • Add descriptions in the Open Specification panel for each shape.
Common Mistakes Beginners Make (and How to Fix Them)
Mistake Why it’s wrong How to fix it
Mixing Component-level details too early Shows packages, classes, or internal modules Delete anything that isn’t independently deployable. Move internals to Level 3.
Forgetting to show technology Defeats the purpose of Level 2 Add tech tags to every container. Use VP’s Technology property field.
Overloading with too many containers Creates visual noise & maintenance burden Cap at 7±2. Group related services logically or split into sub-diagrams.
Unclear or missing relationships Arrows labeled uses or connects to Use verb + noun + protocol. Example: Syncs user profiles (gRPC)
Next Steps After Creating Your Container Diagram
  • Move to Component Diagrams (Level 3): Drill into 1–2 critical containers to show internal packages, classes, or modules.
  • Keep diagrams up-to-date: Tie updates to PR templates or architecture decision records (ADRs). Add Last Updated: YYYY-MM-DD in the footer.
  • Share & get feedback: Use Visual Paradigm’s Share Diagram link for live collaboration. Embed in Confluence, GitHub READMEs, or onboarding wikis. Schedule quarterly architecture reviews.
Conclusion: You’re Now Ready to Visualize Real Architecture
The Container Diagram is where architecture becomes actionable. It gives developers a clear map of what runs where, how data moves, and what tech choices were made. By mastering this level, you prevent integration surprises, accelerate onboarding, and create a living blueprint that evolves with your system.
Your action plan: Pick one active service or feature. Open Visual Paradigm. Draft a Container Diagram using the 5-step guide. Share it with one developer and one stakeholder. Iterate based on feedback. Do this within 7 days.
Bonus Sections (Optional)
Quick Reference Cheat Sheet: C4 Container Diagram Rules
  • ✅ 1 system boundary containing 5–9 containers max
  • ✅ Every container has a technology tag
  • ✅ Arrows labeled: data/action + protocol
  • ✅ Users & external systems carried over from Context
  • No classes, packages, or internal modules
  • ❌ No infrastructure/load balancers/K8s pods
  • 🔄 Version, date, and owner every export
  • 🎨 Use VP C4 theme; distinguish containers vs externals
Glossary of Key Terms for Beginners
  • Container (C4): An independently runnable/deployable unit (app, DB, queue). Not synonymous with Docker.
  • System Boundary: Visual grouping of containers belonging to your system.
  • Technology Tag: Explicit stack identifier (e.g., React, PostgreSQL, Kafka).
  • Relationship Protocol: Communication method (HTTPS, gRPC, JDBC, AMQP, etc.).
  • Component Diagram: C4 Level 3. Shows internal structure of a single container.
Recommended Visual Paradigm Settings for C4 Diagrams
  • Diagram Type: C4 Model > Container Diagram
  • Theme: C4 Default or C4 Light (consistent coloring, auto-styling)
  • Auto-Layout: Hierarchical > Left-to-Right for clean flow
  • Properties Panel: Enable Technology, Description, Responsibility fields
  • Export: PNG/PDF > Include Legend > 300 DPI for documentation
  • AI Assistant: Use structured prompts; always verify tech tags and relationship labels post-generation
  • Versioning: File > Properties > Version Notes + footer timestamp for audit trails
