Comprehensive Guide: C4 Container vs. Component Diagrams
Based on the Internet Banking example, this guide breaks down the differences, key concepts, and best practices for using C4 Level 2 (Container) and Level 3 (Component) diagrams. These diagrams are part of the C4 model, a hierarchical approach to visualizing software architecture.
1. Introduction
The C4 model helps you visualize software architecture at different levels of abstraction.
  • The Container Diagram: Represents Level 2. It zooms into the system to show the high-level technical building blocks (containers).
  • The Component Diagram: Represents Level 3. It zooms into a single container from the previous diagram to show its internal structure.
2. Comparison: Container vs. Component
Feature Container Diagram (Image 1) Component Diagram (Image 2)
Scope The entire System (e.g., Internet Banking System). A single Container (e.g., API Application).
Abstraction Level High-level architecture. Shows "what" runs where. Low-level design. Shows "how" the code is organized.
Primary Elements Web Apps, Mobile Apps, Databases, Microservices, File Systems. Controllers, Services, Repositories, Facades, Modules.
Technology Focus Deployment/Runtime Tech: Java, .NET, Docker, SQL, Angular. Framework/Code Structure: Spring Beans, MVC Controllers, Schemas.
Audience Architects, Developers, Ops/DevOps, Business Stakeholders. Developers, Software Architects.
External Dependencies Shows external systems (e.g., Mainframe, E-Mail System). Shows dependencies of the specific container (e.g., Database, Mainframe).
3. Key Concepts
The "Container"
In C4, a "Container" is not just a Docker container. It is a separately runnable/deployable unit.
  • Examples from Image 1:
    • Web Application: A Java/Spring MVC app delivering static content.
    • Single-Page App: An Angular app running in the browser.
    • Database: An SQL Database storing user info.
    • API Application: A Java/Docker container providing backend logic.
  • Key Takeaway: If you have to deploy it separately or it runs in a separate process, it's a container.
The "Component"
A "Component" is a grouping of related functionality inside a container. It is a logical code structure, not a deployment unit.
  • Examples from Image 2 (Inside the API Application):
    • Sign In Controller: Handles authentication requests.
    • Security Component: A Spring Bean handling passwords.
    • Mainframe Banking System Facade: A wrapper to talk to the external mainframe.
  • Key Takeaway: Components help explain how the code inside the "API Application" is organized without listing every single class file.
4. Guidelines, Tips, and Tricks
For Container Diagrams
  • Include Technology Choices: Notice the text [Java, Spring MVC] or [C#, Xamarin]. This diagram is the perfect place to document what technologies are being used.
  • Show Communication Protocols: The arrows include details like [HTTPS], [async, JSON/HTTPS], and [sync, JDBC]. This is crucial for understanding how containers talk to each other (synchronous vs. asynchronous).
  • Define System Boundaries: Use the dashed line (as seen around "Internet Banking") to clearly separate your system from the outside world (like the "E-Mail System").
For Component Diagrams
  • Don't Model Everything: You do not need a box for every class. Image 2 shows a healthy balance—it groups functionality into logical blocks like "Accounts Summary Controller" rather than listing GetAccount.java, PostAccount.java, etc.
  • Focus on "Interesting" Components: Only model components that are complex or important. Simple CRUD operations might not need a component diagram.
  • Show Internal Dependencies: Notice how the Sign In Controller uses the Security Component. This explains the flow of logic inside the application.
  • Map to External Dependencies: The Mainframe Banking System Facade connects to the external Mainframe Banking System. This shows how the internal code reaches out to the outside world.
5. When to Use What?
Use the Container Diagram  when:
  • Onboarding: You want to show a new developer or stakeholder the "big picture" of the system.
  • Tech Stack Decisions: You need to agree on which languages, databases, and frameworks the team will use.
  • Deployment Planning: You need to figure out how many servers/instances are needed (e.g., "We need a server for the Web App, one for the API, and a DB server").
  • Integration Analysis: You need to see how your system talks to third-party systems (like the Mainframe or E-Mail server).
Use the Component Diagram when:
  • Detailed Design: You are planning the code structure before writing it.
  • Refactoring: You are trying to untangle "spaghetti code" and need to visualize how modules depend on each other.
  • Documentation: You want to document specific parts of the codebase (like the API layer) for other developers.
  • Troubleshooting: You are trying to trace a bug and need to see which component handles which request (e.g., "Ah, the Sign In Controller calls the Security Component").
6. Summary
The relationship between these two diagrams is Zooming In.
  1. Container Diagram gives you the Skeleton of the system. It tells you that the "Internet Banking System" is made of a Web App, a Mobile App, an API, and a Database. It establishes the technology stack.
  2. Component Diagram gives you the Muscles of a specific part. It takes the "API Application" from Image 1 and opens it up to reveal that it is made of Controllers, Security Beans, and Facades.
Final Tip: Start with the Container diagram to get alignment on the architecture. Only drill down into Component diagrams for the containers that are complex or require detailed explanation. Not every container needs a component diagram!
References
  1. C4 Diagram Tool - Visual Paradigm: Comprehensive overview of Visual Paradigm's C4 diagramming capabilities, supporting all six C4 model levels for professional software architecture documentation.
  2. C4 Diagram Solution for Enterprise Architects: Enterprise-focused solution highlighting how Visual Paradigm supports long-term architecture documentation, team collaboration, and precise modeling control.
  3. AI Diagram Generator: Complete C4 Model: Release announcement detailing Visual Paradigm's AI-powered feature that instantly generates the full C4 model suite from natural language descriptions.
  4. C4 Model Tool - VP Online: Cloud-based C4 modeling features in Visual Paradigm Online, enabling collaborative diagram creation with AI assistance and real-time sharing.
  5. AI-Powered C4 PlantUML Markdown Editor: Introduction to the AI-enhanced PlantUML editor that converts natural language into structured C4 diagrams and code, bridging documentation and development workflows.
  6. C4-PlantUML Studio: Dedicated studio environment for writing, editing, and visualizing C4 diagrams using PlantUML syntax, with AI assistance for rapid prototyping.
  7. Visual Paradigm Knowledge Base: Official knowledge base and tutorials for Visual Paradigm users, including step-by-step guides for C4 modeling workflows and tool integration.
  8. AI-Powered C4 PlantUML Studio: Dedicated AI tool page for the C4 PlantUML Studio, featuring natural language to diagram conversion and code-first architecture modeling.
