Comprehensive Guide to Entity Relationship Diagrams (ERDs)
Introduction
An Entity Relationship Diagram (ERD or ER diagram) is a visual representation that illustrates how items in a database relate to each other. As a specialized type of flowchart, ERDs convey relationship types between different entities within a system using defined symbols such as rectangles, ovals, and diamonds connected by lines.
ERDs serve as high-level conceptual data models within the relational model of database design, establishing how entries in a database are connected. They set the foundation for more advanced database design and analysis while helping distill narratives and insights from seemingly disparate collections of data points.
ERDs: Elements explained
This guide provides a comprehensive overview of ERDs, including their uses, components, modeling approaches, styles, and practical implementation examples using PlantUML code.
Key Concepts and Guidelines
1. Core Components of ERDs
Entities
Entities are definable things—people, roles, events, concepts, or objects—that can have information stored about them in a relational database.
  • Representation: Rectangles in most ERD styles
  • Examples:
    • People/Roles: Students, customers, executives
    • Events: Transactions, signups
    • Concepts: User profiles, personas
    • Objects: Products, invoices, emails
Entity Types:
  • Categories of entities (e.g., "vegetables" as a type containing instances like broccoli, carrot, asparagus)
Strong vs. Weak Entities:
  • Strong Entities: Contain sufficient identifying information independently (shown as solid rectangles)
  • Weak Entities: Exist only as outcomes of another entity; depend on a parent/owner entity (shown as double rectangles)
  • Example: In e-commerce, an order is a strong entity, but line items within that order are weak entities
Associative Entities:
  • Link instances between two entity sets with their own attributes
  • Represented as diamonds within rectangles
  • Inform junction tables in relational databases
Attributes
Attributes are qualities, properties, and characteristics that define an entity.
  • Representation: Ovals displayed next to corresponding entities
Types of Attributes:
  1. Simple Attributes: Cannot be split further (e.g., ZIP code)
  2. Composite Attributes: Compiled from other attributes (e.g., address containing street, city, ZIP)
  3. Derived Attributes: Calculated from other attributes (shown as dashed ovals; e.g., paycheck value)
  4. Multivalue Attributes: Can have multiple values per record
Key Attributes:
  • Super Key: One or more attributes that uniquely define an entity
  • Candidate Key: Simplest possible super key
  • Primary Key: Chosen candidate key that uniquely defines an entity set (underlined in ERDs); no two entries share the same primary key
  • Foreign Key: Identifies one entity's relationship to another; weak entities rely on foreign keys
Relationships
Relationships indicate how entities are associated with each other—the "verbs" connecting the "nouns."
  • Representation: Diamonds in traditional ERDs; weak relationships shown as double diamonds
  • Participation:
    • Total Participation: Entire entity set involved in the relationship
    • Partial Participation: Some or all entities involved at any specific time
Relationship Cardinality:
  1. One-to-One (1:1): One record in one entity references only one record in another
    • Example: University ↔ President
  2. One-to-Many (1:M): One record relates to multiple records in another entity
    • Example: University ↔ Departments
  3. Many-to-Many (M:M): Multiple records in both entities can connect
    • Example: Students ↔ Professors
2. What Are ERDs Used For?
Database Design and Data Modeling
  • Business analysts and database engineers use ERDs to assess database scope and plan data storage
  • ERDs inform software engineering by laying out requirements for information systems architecture
  • In the three-schema approach, ERDs represent the conceptual tier
  • Help data engineers conceptualize overall systems and reduce errors during data integration
Database Problem-Solving
  • Comparing existing databases to ERDs reveals design missteps causing problems
  • Summarize complex databases so engineers can quickly identify potential errors without extensive SQL debugging
Business Process Reengineering (BPR)
  • Provide bird's-eye views of all organizational data within information systems
  • Draft newer, more efficient data architecture solutions facilitating BPR stages
3. Comparing ERDs with Related Diagrams
Diagram Type Purpose Focus
Entity Relationship Diagrams Illustrate entities and their relationships Database structure and entity connections
Database Schemas Establish rules for modeling real-world entities Table names, fields, data types, organization guidelines
Data Flow Diagrams Depict data movement through processes How data flows from process to storage locations
4. Types of ER Models
Conceptual ER Models
  • High-level view of data
  • Used by business analysts for large-scale projects (e.g., data warehouses)
  • Contains entities and relationships without detailed cardinality or table structures
  • Least detailed model
Logical ER Models
  • Similar to conceptual but with more detail
  • Defines columns/attributes within each entity
  • Includes operational and transactional entities
  • Used for smaller-scale database design projects
Physical ER Models
  • Concrete blueprints for database implementation
  • Maximum detail including cardinality, primary keys, and foreign keys
  • Created by database designers/engineers from conceptual and logical models
  • Most granular model
5. ERD Styles
Chen Style
  • Introduced by Peter Chen in the 1970s
  • Uses various shapes connected by lines (similar to classical flowcharts)
  • Cardinality shown with characters: 1, M, N (where M and N represent "many")
  • Total participation: single connecting line; Partial participation: double connecting line
Crow's Foot Notation
  • Named for three-pronged forked lines showing "many" relationships
  • Replaces Chen's symbols with tables representing entities
  • Each table contains all attributes
  • Clearly shows relationship cardinality
Bachman Style
  • Charles Bachman's data structure diagrams inspired Chen
  • Uses lines with arrows to indicate cardinality
IDEF1X Style
  • Introduced by US Air Force in the 1980s
  • Supports semantic data model development
  • Displays attributes within shared tables
  • Offers more cardinality options than Chen style
Barker Style
  • Created by Richard Barker in 1981
  • Standard for Oracle databases
  • Shares crow's foot style for connecting lines
  • Uses dashed lines for partial/optional participation
Practical Examples with PlantUML Code
Below are practical ERD examples using PlantUML, a popular tool for creating diagrams from text descriptions.
Example 1: University Database (Conceptual Model)
This example demonstrates a university system with students, professors, courses, and departments.
@startuml
skinparam rectangle {
    BackgroundColor White
    BorderColor Black
entity Student {
  * student_id : int <<PK>>
  first_name : string
  last_name : string
  email : string
  enrollment_date : date
entity Professor {
  * professor_id : int <<PK>>
  first_name : string
  last_name : string
  department : string
  hire_date : date
entity Course {
  * course_id : int <<PK>>
  course_name : string
  credits : int
  semester : string
entity Department {
  * dept_id : int <<PK>>
  dept_name : string
' Relationships
Student "1" -- "M" Course : enrolls_in
Professor "1" -- "M" Course : teaches
Department "1" -- "M" Professor : employs
Department "1" -- "M" Course : offers
@enduml
Explanation:
  • Students enroll in many courses (M:M relationship would require an associative entity in physical model)
  • Professors teach multiple courses
  • Departments employ multiple professors and offer multiple courses
Example 2: E-Commerce System (Physical Model with Associative Entity)
This example shows an e-commerce database with orders, products, and line items.
@startuml
    BorderColor Black
entity Customer {
  * customer_id : int <<PK>>
  first_name : string
  last_name : string
  email : string
  phone : string
  address : string
entity Order {
  * order_id : int <<PK>>
  order_date : date
  total_amount : decimal
  status : string
  # customer_id : int <<FK>>
entity Product {
  * product_id : int <<PK>>
  product_name : string
  description : string
  price : decimal
  stock_quantity : int
entity OrderItem {
  * order_item_id : int <<PK>>
  quantity : int
  unit_price : decimal
  # order_id : int <<FK>>
  # product_id : int <<FK>>
' Relationships
Customer "1" -- "M" Order : places
Order "1" -- "M" OrderItem : contains
Product "1" -- "M" OrderItem : includes
@enduml
Key Points:
  • Order is a strong entity with its own primary key
  • OrderItem is a weak entity dependent on Order (existence dependency)
  • OrderItem serves as an associative entity linking Orders and Products
  • Foreign keys (customer_id, order_id, product_id) establish relationships
Example 3: Employee Management System (With Composite and Derived Attributes)
@startuml
    BorderColor Black
entity Employee {
  * employee_id : int <<PK>>
  first_name : string
  last_name : string
  email : string
  hire_date : date
  hourly_wage : decimal
entity Department {
  dept_name : string
  manager_id : int <<FK>>
entity Project {
  * project_id : int <<PK>>
  project_name : string
  start_date : date
  end_date : date
  budget : decimal
entity Assignment {
  * assignment_id : int <<PK>>
  hours_worked : int
  start_date : date
  end_date : date
  # employee_id : int <<FK>>
  # project_id : int <<FK>>
' Relationships
Department "1" -- "M" Employee : employs
Employee "M" -- "M" Project : works_on (through Assignment)
Employee "1" -- "1" Department : manages
note right of Employee
  Derived attribute example:
  Annual Salary = hourly_wage × 2080
end note
@enduml
Features Demonstrated:
  • Many-to-many relationship between Employees and Projects resolved through associative entity Assignment
  • Note showing derived attribute calculation (annual salary from hourly wage)
  • Self-referencing relationship (manager within Department)
Example 4: Library System (Using Crow's Foot Notation Concept)
@startuml
    BorderColor Black
entity Member {
  * member_id : int <<PK>>
  email : string
  membership_date : date
  membership_type : string
entity Book {
  * isbn : string <<PK>>
  title : string
  author : string
  publication_year : int
  genre : string
  available_copies : int
entity Loan {
  * loan_id : int <<PK>>
  loan_date : date
  due_date : date
  return_date : date
  # member_id : int <<FK>>
  # isbn : string <<FK>>
' Relationships
Member "1" -- "M" Loan : borrows
Book "1" -- "M" Loan : is_loaned
note bottom of Loan
  Loan is an associative entity
  linking Members and Books
end note
@enduml
Best Practices and Guidelines
When Creating ERDs:
  1. Start with Conceptual Models: Begin with high-level entities and relationships before adding attributes and cardinality details
  2. Identify Strong vs. Weak Entities Early: Determine which entities can exist independently and which depend on others
  3. Choose Appropriate Primary Keys: Select attributes that uniquely identify each entity instance; avoid using mutable data as primary keys
  4. Resolve Many-to-Many Relationships: Use associative entities to break down M:M relationships into two 1:M relationships for physical implementation
  5. Document Cardinality Clearly: Ensure relationship cardinality (1:1, 1:M, M:M) is explicitly shown using your chosen notation style
  6. Consider Participation Constraints: Indicate whether entity participation in relationships is total or partial
  7. Use Consistent Naming Conventions: Maintain consistent naming for entities, attributes, and relationships throughout the diagram
  8. Validate with Stakeholders: Review ERDs with business analysts, developers, and end-users to ensure accuracy
  9. Iterate Through Model Types: Progress from conceptual → logical → physical models as requirements become clearer
  10. Keep Diagrams Readable: Avoid overcrowding; split complex systems into multiple focused diagrams if necessary
Summary
Entity Relationship Diagrams are essential tools for database design, providing visual representations of how data entities relate to each other. By understanding the core components—entities, attributes, and relationships—and their various types, you can create effective ERDs that serve multiple purposes:
  • Database design and planning for new systems
  • Problem-solving by identifying design issues in existing databases
  • Business process reengineering through comprehensive data architecture views
The three model types (conceptual, logical, physical) allow you to communicate at appropriate levels of detail for different audiences, while various ERD styles (Chen, Crow's Foot, IDEF1X, etc.) provide flexibility for different use cases and tools.
By following best practices and using tools like PlantUML to generate clear, maintainable diagrams, you can leverage ERDs to build robust, well-structured databases that accurately reflect your organization's data needs and support efficient information systems.
