Comprehensive Guide to Stereotypes and Profiles in UML
In UML, stereotypes and profiles provide a language-inherent extension mechanism, allowing modelers to adapt the general-purpose Unified Modeling Language to specific domains or technologies without modifying the core metamodel. This is known as a lightweight extension, which ensures that different modeling tools remain interoperable.
1. Stereotypes
A stereotype is a special metaclass in the UML metamodel used to extend existing metaclasses (like Class, Component, or Interface) with additional properties and constraints.
  • Core Concepts:
    • Extension: A stereotype makes a metaclass more specific but leaves the original definition unchanged.
    • Meta-attributes (Tagged Values): These are additional attributes defined within the stereotype to store extra information about the model element.
    • Constraints: Stereotypes can include specific rules that the extended element must follow.
  • Notation:
    • Represented as a rectangle similar to a class, but with the keyword «stereotype» above the name.
    • Special pictograms or symbols can also be assigned to a stereotype to represent its elements visually.
  • Extension Relationship:
    • Shown as an arrow with a solid line and a filled arrowhead pointing from the stereotype to the extended metaclass (labeled «metaclass»).
    • Extensions can be optional or mandatory. Mandatory extensions are marked with the keyword {required}, meaning every instance of that metaclass in the model must use the stereotype.
  • Inheritance: Stereotypes can inherit from other stereotypes, allowing more specific stereotypes to adopt the meta-attributes and constraints of their parent.
2. Profiles
A profile is a specialized form of a package that groups together a set of stereotypes, constraints, and data types designed for a specific purpose or domain.
  • Purpose: Profiles allow UML to be customized for specific technologies, such as Java Enterprise Beans (EJB) or web applications.
  • Notation: Represented by a package symbol with the keyword «profile» prepended to the name.
  • Domain-Specific Languages (DSL): By using profiles, modelers can create smaller languages tailored to a domain while remaining within the standardized framework of UML.
3. Applying Stereotypes and Profiles
To use the custom concepts defined in a profile within a model, the profile must be explicitly applied to a package.
  • Application Process:
    • A dashed arrow with an open arrowhead points from the model package to the profile, labeled with the keyword «apply».
    • This application imports the stereotypes into the namespace of the package, making them available for use on model elements.
  • Usage in Models:
    • Once applied, a stereotype is displayed on a model element by placing its name in guillemets (e.g., «session») above the element's name.
    • Specific values for the stereotype's meta-attributes (tags) are often noted within the element or in an attached note.
Key Benefits of the Profile Mechanism
  • Interoperability: Because profiles only extend existing metaclasses rather than creating new ones, modeling tools that do not recognize a specific profile can still understand the basic UML elements.
  • Precision: Profiles provide the vocabulary needed to model complex technical or organizational requirements that general UML might otherwise describe too vaguely.
  • Model-Based Development: They are essential for Model-Based Software Development (MBSD), providing the unambiguous semantics required to automatically transform models into executable code.
