From Context to Containers: A Practical Guide to C4 Architecture Drilling in Visual Paradigm
Bridging business scope and technical implementation with clear, maintainable architecture diagrams.
The C4 Model (created by Simon Brown) provides a hierarchical approach to visualizing software architecture. By moving from a System Context Diagram (Level 1) to a Container Diagram (Level 2), teams translate high-level business interactions into actionable technical blueprints. This guide walks you through the practical, step-by-step process of drilling down in Visual Paradigm, ensuring consistency, clarity, and traceability across architecture artifacts.
🔍 Why Drill Down? Business & Technical Value
Drilling down from Context to Container isn’t just about adding boxes and arrows. It’s a deliberate architectural exercise that delivers measurable value:
Benefit Impact
Scope-to-Implementation Bridge Aligns stakeholder expectations with engineering reality.
Early Technology Visibility Surfaces stack choices (e.g., React, Spring Boot, PostgreSQL) before coding begins.
Deployment & Integration Mapping Clarifies boundaries, sync/async flows, and third-party dependencies.
Risk & Compliance Readiness Highlights security perimeters, data sovereignty, and scalability bottlenecks.
Team Alignment Accelerates onboarding, architecture reviews, threat modeling, and DevOps planning.
Best Practice: Create the Context diagram first. Drill down only into primary systems in scope. Keep Container diagrams focused: 5–10 containers maximum for optimal readability.
🛠️ Step-by-Step: From Context (C1) to Container (C2)
1. Prepare & Validate Your Context Diagram
The Context diagram treats your system as a single black box. It must be accurate before you decompose it.
In Visual Paradigm:
  1. Navigate to Diagram > New > C4 > System Context Diagram (or use the C4 Template Gallery).
  2. Define core elements:
    • Central Software System: Clear name + concise responsibility statement.
    • Persons: External actors (e.g., Customer, Support Agent, Admin).
    • External Systems: Third parties or legacy platforms (e.g., Payment Gateway, Core Banking API).
  3. Draw labeled relationships using verb + protocol/technology (e.g., Submits payments via HTTPS, Syncs user profiles via OAuth2).
  4. Add a legend for shapes, line styles, and color conventions.
💡 VP Tip: Use the dedicated C4 Shape Library. Leverage VP’s AI-assisted generation by describing your scope in natural language to bootstrap a draft, then refine manually.
2. Identify & Define Your Containers
A C4 Container is not a Docker/Kubernetes container. It represents any independently deployable or runnable unit that holds code or data.
Key Questions to Answer:
  • Where does the user interface live?
  • Where is business logic executed?
  • Where is data persisted or cached?
  • Which components run synchronously vs. asynchronously?
  • Are there gateways, batch processors, or integration wrappers?
Documentation Practice: Assign one primary responsibility per container. Record technology stack, hosting model, and communication patterns in element properties or linked Architecture Decision Records (ADRs).
3. Build the Container Diagram in Visual Paradigm
Choose the workflow that best fits your team’s maturity and timeline:
Option A: Manual / Drag-and-Drop (Maximum Control)
  1. Diagram > New > C4 > Container Diagram
  2. Copy or reference external Persons and Software Systems from your C1 diagram.
  3. Draw a System Boundary (dashed rectangle) representing the original black box.
  4. Place Container shapes inside the boundary. Include:
    • Name
    • Technology (in brackets or description)
    • Short responsibility statement
  5. Connect external actors to specific containers. Add internal container relationships with direction, protocol, and purpose.
  6. Use VP’s auto-layout tools to clean up routing and minimize line crossings.
Option B: AI-Assisted Generation (Fast Iteration)
Prompt example:
Create a C4 Container diagram for an Online Banking System. Inside: Web App (React), Mobile App (Flutter), API Backend (Spring Boot), PostgreSQL DB, Redis Cache. Customers interact via web/mobile; external Payment Provider connects to the API.
Refine iteratively: Add a Kafka-based Notification Service or Extract Authentication to a dedicated Auth Container.
Option C: Sub-Diagram Linking (Recommended for Traceability)
In your Context diagram, right-click the central Software System → Create Sub-Diagram > Container Diagram. Visual Paradigm automatically links boundaries and external relationships, preserving hierarchy and model consistency.
Option D: OpenAPI / Plugin Automation (Advanced)
For large enterprises, use VP’s OpenAPI or plugin framework to script diagram generation from model repositories or code metadata. Ideal for CI/CD documentation pipelines.
4. Refine, Validate & Maintain
Validation Step Action
Consistency Check Verify element names, descriptions, and relationships trace cleanly to C1.
Detail Balance Include tech stack, sync/async style, and key protocols. Omit implementation logic (save for Component level).
Layout & Readability Group by tier (UI → Business Logic → Data). Use sparing, intentional color. Add a legend.
Review Cycle Walk through with developers, DevOps, and stakeholders. Validate responsibilities and integration points.
Version Control Store in VP project, export to PDF/PNG, or sync with Confluence/Jira. Update as architecture evolves.
📐 Common Architectural Patterns & Examples
Pattern Structure External Integration Points
Web + Mobile + API + DB Customer → Web App / Mobile App → API Backend → Database Payment/Identity providers connect to API only
Microservices API Gateway → [Order, Inventory, Billing] Services → Shared DBs / Event Bus External systems route through Gateway or specific services
Hybrid / Strangler Fig Legacy Monolith + New Reporting Service + Migration Proxy Proxy routes traffic; new service reads from replicated data
Event-Driven Producers → Message Broker (Kafka/RabbitMQ) → Consumers → Data Stores External systems publish/subscribe to topics/queues
Example Drill-Down Narrative:
  • C1: Online Banking System interacts with Customer and External Payment Provider.
    PlantUML Code:
    @startuml
    !include <C4/C4_Context>
    title System Context Diagram (C1): Online Banking System
    ' External Actors & Systems
    Person(customer, "Customer", "Retail banking client who manages accounts and initiates payments")
    System_Ext(payment_provider, "External Payment Provider", "Third-party gateway for payment processing, clearing, and settlement")
    ' Central Software System (Black Box)
    System(banking_system, "Online Banking System", "Provides secure retail banking services via web and mobile channels")
    ' Relationships
    Rel(customer, banking_system, "Accesses accounts & submits payments", "HTTPS / Web & Mobile")
    Rel(banking_system, payment_provider, "Routes payment requests & verifies status", "HTTPS / REST API")
    @enduml
  • C2: Customer → Web Application (React) & Mobile App (Flutter) → API Application (Spring Boot) → PostgreSQL & Redis Cache. API communicates with Payment Provider via HTTPS. Async notifications flow through Kafka → Email Service.
    PlantUML Code:
    @startuml
    !include <C4/C4_Container>
    title Container Diagram: Online Banking System
    Person(customer, "Customer", "Banking client accessing services via web or mobile")
    System_Ext(payment_provider, "External Payment Provider", "Third-party payment processing & settlement service")
    System_Boundary(banking_system, "Online Banking System") {
    Container(web_app, "Web Application", "React, TypeScript", "Provides responsive web UI for account management and transactions")
    Container(mobile_app, "Mobile App", "Flutter, Dart", "Provides native-feel mobile interface and push notifications")
    Container(api_app, "API Application", "Spring Boot, Java", "Core business logic, routing, authentication, and payment orchestration")
    ContainerDb(postgres_db, "Customer Database", "PostgreSQL", "Persists accounts, transaction history, and user profiles")
    Container(redis_cache, "Redis Cache", "Redis", "Stores session state, rate limits, and frequently accessed data")
    Container(kafka_broker, "Message Broker", "Apache Kafka", "Asynchronous event streaming for notifications and audit trails")
    Container(email_service, "Email Service", "Node.js, SMTP", "Consumes events to send transactional and security alerts")
    Rel(customer, web_app, "Uses", "HTTPS")
    Rel(customer, mobile_app, "Uses", "HTTPS")
    Rel(web_app, api_app, "Submits requests", "HTTPS/REST")
    Rel(mobile_app, api_app, "Submits requests", "HTTPS/REST")
    Rel(api_app, postgres_db, "Reads/Writes data", "TCP/SQL")
    Rel(api_app, redis_cache, "Reads/Writes cache", "TCP/RESP")
    Rel(api_app, payment_provider, "Submits payments & verifies", "HTTPS/OAuth2")
    Rel(api_app, kafka_broker, "Publishes events", "Async/Kafka")
    Rel(kafka_broker, email_service, "Consumes events", "Async/Kafka")
    Rel(email_service, customer, "Sends notifications", "SMTP/Email")
    @enduml
🧰 Visual Paradigm: Pro Tips & Workflow Shortcuts
  • Model Repository: Store elements centrally. Reuse across diagrams to enforce naming/tech consistency.
  • C4 Stencils: Use built-in shapes with dedicated Technology and Responsibility fields.
  • AI Chatbot: Ideal for rapid prototyping. Prompt: Now zoom into the API container for a Component view.
  • Export & Integration: High-resolution PNG/SVG/PDF. Compatible with PlantUML in select configurations. Supports real-time collaboration for distributed teams.
  • Notes & Links: Attach ADRs, runbooks, or deployment diagrams to containers using VP’s documentation pane.
⚠️ Pitfalls to Avoid
Mistake Consequence Fix
Treating “Container” as only Docker/K8s Misaligned mental model, missing monoliths/batch jobs Use C4 definition: any deployable/runnable unit
Overloading the diagram Cognitive overload, unreadable layouts Cap at 5–10 containers. Push details to C3/C4
Inconsistent naming across levels Broken traceability, stakeholder confusion Reuse model elements. Audit names before sharing
Dropping external systems in C2 Lost integration context, security blind spots Keep Persons & External Systems visible; route to correct containers
Diagrams in isolation Siloed documentation, outdated artifacts Use sub-diagrams, version control, and regular review cycles
✅ Quick-Reference Checklist
  • Context diagram validated & approved by stakeholders
  • Containers defined by deployable unit, not infrastructure abstraction
  • Each container has: Name, Technology, Responsibility
  • External actors/systems routed to specific containers
  • Sync/async flows & protocols labeled on relationships
  • Layout clean, grouped by tier, legend included
  • Sub-diagram linked to C1 for traceability
  • Reviewed by Dev, Ops, and Security stakeholders
  • Exported & published to team knowledge base
  • Scheduled for review/update with next architecture milestone
📝 Conclusion
Drilling down from a C4 Context Diagram to a Container Diagram is a disciplined, repeatable process that transforms high-level scope into technical clarity. By leveraging Visual Paradigm’s C4 tooling, model repository, and hierarchical linking features, teams produce architecture documentation that scales alongside the system itself.
Start small. Iterate deliberately. Keep diagrams living artifacts, not static posters. When Context and Container views align, you empower engineers to build confidently, operations to deploy safely, and stakeholders to understand clearly.
For the latest interface details and AI capabilities, refer to Visual Paradigm’s official documentation. Architecture evolves—your diagrams should too.
