Mapping Class Diagrams to Entity-Relationship Diagrams (ERD): A Beginner's Step-by-Step Guide
Introduction
When designing software systems, developers often start with object-oriented class diagrams and then need to translate those designs into database schemas. Understanding how to map class diagrams to Entity-Relationship Diagrams (ERDs) is crucial for building efficient, well-structured databases. This guide will walk you through the process step by step, with practical examples using PlantUML.
Key Concepts
What is a Class Diagram?
A class diagram represents the structure of a system using classes, their attributes, methods, and relationships (associations, inheritance, composition).
What is an ERD?
An Entity-Relationship Diagram represents the logical structure of a database using entities (tables), attributes (columns), and relationships between entities.
Why Map Between Them?
  • Object-Relational Impedance Mismatch: Objects and relational databases have different structures
  • Persistence Layer Design: Ensures your database supports your application's object model
  • Data Integrity: Proper mapping maintains relationships and constraints
Step-by-Step Mapping Process
Step 1: Identify Classes That Become Entities
Rule: Not every class becomes a table. Generally:
  • ✅ Regular classes → Entities/Tables
  • ❌ Utility/helper classes → No table needed
  • ❌ Abstract classes (usually) → No direct table
  • ⚠️ Interface implementations → Depends on strategy
@startuml
' Original Class Diagram
class User {
    +userId: int
    +username: string
    +email: string
    +createdAt: datetime
class Order {
    +orderId: int
    +orderDate: datetime
    +totalAmount: decimal
class Product {
    +productId: int
    +name: string
    +price: decimal
class EmailService {
    +sendEmail(to: string, body: string)
User "1" --> "*" Order : places
Order "*" --> "*" Product : contains
@enduml
Mapping Result: User, Order, and Product become tables. EmailService does not.
Step 2: Map Attributes to Columns
Rules:
  • Simple data types (int, string, date) → Direct column mapping
  • Complex objects → May need separate tables or serialization
  • Collections → Usually require separate relationship tables
@startuml
' ERD Representation
entity User {
    * userId : int <<PK>>
    username : varchar(50)
    email : varchar(100)
    createdAt : datetime
entity Order {
    * orderId : int <<PK>>
    orderDate : datetime
    totalAmount : decimal(10,2)
    userId : int <<FK>>
entity Product {
    * productId : int <<PK>>
    price : decimal(10,2)
@enduml
Step 3: Handle Relationships
One-to-Many (1:N)
Class Diagram: One class has a collection of another
@startuml
' Class Diagram - One-to-Many
class Customer {
    +customerId: int
    +name: string
class Order {
    +orderId: int
Customer "1" --> "*" Order : places
@enduml
ERD Mapping: Add foreign key to the "many" side
@startuml
' ERD - One-to-Many
entity Customer {
    * customerId : int <<PK>>
entity Order {
    customerId : int <<FK>>
Customer ||--o{ Order : places
@enduml
Many-to-Many (M:N)
Class Diagram: Both classes have collections of each other
@startuml
' Class Diagram - Many-to-Many
class Student {
    +studentId: int
    +name: string
class Course {
    +courseId: int
    +title: string
Student "*" --> "*" Course : enrolls_in
@enduml
ERD Mapping: Create a junction/join table
@startuml
' ERD - Many-to-Many with Junction Table
entity Student {
    * studentId : int <<PK>>
entity Course {
    * courseId : int <<PK>>
    title : varchar(200)
entity Enrollment {
    * studentId : int <<PK, FK>>
    * courseId : int <<PK, FK>>
    enrollmentDate : datetime
    grade : char(2)
Student }|--|| Enrollment : has
Course }|--|| Enrollment : has
@enduml
One-to-One (1:1)
Class Diagram: Each instance relates to exactly one instance
@startuml
' Class Diagram - One-to-One
class User {
    +userId: int
    +username: string
class UserProfile {
    +profileId: int
    +bio: string
    +avatar: string
User "1" --> "1" UserProfile : has
@enduml
ERD Mapping Options:
Option A: Foreign key in either table
@startuml
' ERD - One-to-One (FK approach)
entity User {
    profileId : int <<FK, unique>>
entity UserProfile {
    * profileId : int <<PK>>
    bio : text
    avatar : varchar(255)
User ||--|| UserProfile : has
@enduml
Option B: Merge into single table (if tightly coupled)
Step 4: Handle Inheritance
Three common strategies:
Strategy 1: Single Table Inheritance
All classes in hierarchy share one table with a discriminator column
@startuml
' Class Diagram - Inheritance
class Payment {
    +paymentId: int
    +amount: decimal
    +date: datetime
class CreditCardPayment {
    +cardNumber: string
    +expiryDate: string
class BankTransferPayment {
    +accountNumber: string
    +routingNumber: string
Payment <|-- CreditCardPayment
Payment <|-- BankTransferPayment
@enduml
@startuml
' ERD - Single Table Inheritance
entity Payment {
    * paymentId : int <<PK>>
    amount : decimal(10,2)
    date : datetime
    paymentType : varchar(20) <<discriminator>>
    cardNumber : varchar(20)
    expiryDate : varchar(7)
    accountNumber : varchar(20)
    routingNumber : varchar(9)
@enduml
Strategy 2: Class Table Inheritance
Each class gets its own table
@startuml
' ERD - Class Table Inheritance
entity Payment {
    date : datetime
entity CreditCardPayment {
    * paymentId : int <<PK, FK>>
entity BankTransferPayment {
Payment ||--|| CreditCardPayment : extends
Payment ||--|| BankTransferPayment : extends
@enduml
Strategy 3: Concrete Table Inheritance
Only concrete classes get tables (no parent table)
@startuml
' ERD - Concrete Table Inheritance
    date : datetime
    date : datetime
@enduml
Step 5: Handle Composition and Aggregation
Composition (Strong Ownership)
The contained object cannot exist without the container
@startuml
' Class Diagram - Composition
class Invoice {
    +invoiceId: int
    +invoiceDate: datetime
class LineItem {
    +lineItemId: int
    +quantity: int
    +unitPrice: decimal
Invoice *-- LineItem : contains
@enduml
@startuml
' ERD - Composition
entity Invoice {
* invoiceId : int <<PK>>
invoiceDate : datetime
entity LineItem {
* lineItemId : int <<PK>>
quantity : int
unitPrice : decimal(10,2)
invoiceId : int <<FK>>
Invoice ||--|{ LineItem : contains
@enduml
Step 6: Handle Associations with Attributes
When associations themselves have attributes, create a separate entity
@startuml
' Class Diagram - Association with Attributes
class Employee {
    +employeeId: int
    +name: string
class Project {
    +projectId: int
    +projectName: string
Employee "*" --> "*" Project : works_on
note right: Association has attributes:\n- startDate\n- role\n- hoursPerWeek
@enduml
@startuml
' ERD - Association as Entity
entity Employee {
    * employeeId : int <<PK>>
entity Project {
    * projectId : int <<PK>>
    projectName : varchar(200)
entity Assignment {
    * employeeId : int <<PK, FK>>
    * projectId : int <<PK, FK>>
    startDate : date
    role : varchar(50)
    hoursPerWeek : int
Employee }|--|| Assignment : assigned_to
Project }|--|| Assignment : includes
@enduml
Complete Example: E-Commerce System
Let's map a complete class diagram to an ERD:
@startuml
' Complete Class Diagram
class Customer {
    +customerId: int
    +firstName: string
    +lastName: string
    +email: string
    +phone: string
class Address {
    +addressId: int
    +street: string
    +city: string
    +state: string
    +zipCode: string
class Order {
    +orderId: int
    +status: string
    +shippingAddress: Address
class OrderItem {
    +orderItemId: int
    +quantity: int
    +unitPrice: decimal
class Product {
    +productId: int
    +name: string
    +description: string
    +price: decimal
    +stockQuantity: int
class Category {
    +categoryId: int
    +categoryName: string
Customer "1" --> "*" Address : has
Order "1" *-- "*" OrderItem : contains
OrderItem "*" --> "1" Product : refers_to
Product "*" --> "*" Category : belongs_to
Category "1" --> "*" Product : categorizes
@enduml
@startuml
' Complete ERD
entity Customer {
firstName : varchar(50)
lastName : varchar(50)
phone : varchar(20)
entity Address {
* addressId : int <<PK>>
street : varchar(200)
city : varchar(100)
state : varchar(50)
zipCode : varchar(10)
entity Order {
status : varchar(20)
shippingAddressId : int <<FK>>
entity OrderItem {
* orderItemId : int <<PK>>
quantity : int
orderId : int <<FK>>
productId : int <<FK>>
entity Product {
description : text
stockQuantity : int
entity Category {
* categoryId : int <<PK>>
categoryName : varchar(100)
entity ProductCategory {
* productId : int <<PK, FK>>
* categoryId : int <<PK, FK>>
Customer ||--o{ Address : has
Order ||--|{ OrderItem : contains
Product ||--o{ OrderItem : referenced_by
OrderItem }|--|| Order : part_of
OrderItem }|--|| Product : refers_to
Product }|--|| ProductCategory : categorized_in
Category }|--|| ProductCategory : contains
@enduml
Guidelines and Best Practices
1. Naming Conventions
  • Tables: Use plural nouns (e.g., users, orders)
  • Columns: Use snake_case (e.g., user_id, created_at)
  • Foreign Keys: Follow pattern [table_name]_id (e.g., customer_id)
2. Data Type Mapping
Class Type Database Type Notes
int/Integer INT Consider BIGINT for large datasets
long/Long BIGINT For very large numbers
String VARCHAR(n) Choose appropriate length
Text/long string TEXT For unlimited length
boolean/Boolean BOOLEAN/TINYINT Database dependent
Date DATE Date only
DateTime DATETIME/TIMESTAMP Date and time
Decimal/BigDecimal DECIMAL(p,s) Specify precision and scale
Double/Float FLOAT/DOUBLE Be aware of precision issues
3. Indexing Strategy
  • Always index primary keys (automatic)
  • Index foreign keys for join performance
  • Index columns used in WHERE clauses frequently
  • Consider composite indexes for multi-column queries
4. Normalization
  • 1NF: Atomic values, no repeating groups
  • 2NF: Remove partial dependencies
  • 3NF: Remove transitive dependencies
  • Balance normalization with performance needs
5. Common Pitfalls to Avoid
❌ Creating tables for every class
  • Utility classes, services, and interfaces typically don't need tables
❌ Ignoring cardinality
  • Misunderstanding 1:1 vs 1:N vs M:N leads to incorrect schema
❌ Forgetting about referential integrity
  • Always define foreign key constraints
❌ Over-normalizing or under-normalizing
  • Find the right balance for your use case
❌ Not considering query patterns
  • Design with actual usage in mind
Quick Reference Checklist
When mapping class diagrams to ERDs:
  1. ✅ Identify which classes become entities
  2. ✅ Map simple attributes to columns
  3. ✅ Determine relationship cardinalities
  4. ✅ Add foreign keys for 1:N relationships
  5. ✅ Create junction tables for M:N relationships
  6. ✅ Choose inheritance strategy
  7. ✅ Handle composition/aggregation appropriately
  8. ✅ Create entities for associations with attributes
  9. ✅ Define primary and foreign keys
  10. ✅ Add appropriate indexes
  11. ✅ Validate against query requirements
  12. ✅ Review for normalization
Mapping class diagrams to ERDs is a systematic process that requires understanding both object-oriented design and relational database principles. By following these steps and guidelines, you can create database schemas that accurately represent your application's domain model while maintaining data integrity and performance.
Remember:
  • Start with clear class diagrams
  • Understand relationship cardinalities
  • Choose appropriate inheritance strategies
  • Balance normalization with practical needs
  • Always consider your actual query patterns
With practice, this mapping process becomes intuitive, enabling you to design robust database schemas that support your application's object model effectively.
This guide provides foundational knowledge for beginners. As you gain experience, you'll encounter more complex scenarios requiring advanced techniques like polymorphic associations, soft deletes, and denormalization for performance optimization.
