Use Case 2.0: The Complete Guide for Agile Requirements
Use Case 2.0 represents the evolution of traditional use case modeling for modern Agile development. Created by Ivar Jacobson and his team, it bridges the gap between comprehensive requirements capture and the flexibility needed for iterative delivery . This guide covers everything beginners need to know, with practical examples and PlantUML diagrams.
Use Case 2.0: Evolution for Agile Development
1. Traditional Use Cases: The Foundation
Traditional use case methodology involves creating detailed documents to capture functional requirements. A typical use case includes :
  • Brief description of system behavior
  • Preconditions (what must be true before the use case starts)
  • Post-conditions (what must be true after completion)
  • Actors (who interacts with the system)
  • Detailed flow of steps (basic flow, alternative flows, exception flows)
Example: Traditional "Withdraw Cash" Use Case (ATM)
Use Case: Withdraw Cash
Actor: Customer
Precondition: Customer has valid ATM card and PIN
Postcondition: Cash dispensed, account balance updated
Basic Flow:
1. Customer inserts ATM card
2. System validates card
3. Customer enters PIN
4. System validates PIN
5. Customer selects "Withdrawal"
6. Customer enters amount
7. System checks sufficient balance
8. System dispenses cash
9. System prints receipt
10. Customer removes card
Alternative Flow 1: Insufficient Funds
   Step 7a: System detects insufficient balance
   Step 7b: System displays error message
   Step 7c: Return to step 5
Alternative Flow 2: Invalid PIN
   Step 4a: System detects invalid PIN
   Step 4b: System displays error
   Step 4c: After 3 failures, system retains card
The Problem: Traditional use cases are written as large documents upfront. They work for waterfall projects but become too heavy for Agile teams. Requirements change, and maintaining these documents becomes a burden .
2. What is Use Case 2.0?
Use Case 2.0 is a lightweight, Agile-friendly evolution of traditional use cases. It was inspired by user stories, Scrum, and Kanban, bringing together the best of both worlds .
The Six Core Principles
  1. Keep it simple by telling stories - Use cases capture goals through storytelling
  2. Understand the big picture - Use case diagrams show system boundaries and actors
  3. Focus on value - Every use case delivers observable value to users
  4. Build the system in slices - Break use cases into manageable, valuable pieces
  5. Deliver the system in increments - Release working software regularly
  6. Adapt to meet team's needs - Scale up or down as required
Key Differences at a Glance
Aspect Traditional Use Case Use Case 2.0
Approach Waterfall, upfront documentation Agile, iterative, just-in-time
Work Unit Complete use case document Use Case Slice (small, valuable piece)
Planning Document everything first Backlog-driven, prioritize by value
Testing After development Test cases derived from stories, early testing
Change Difficult, expensive to change Flexible, adapts to changing requirements
Format Heavy documents Lightweight narratives + visual models
3. Core Concepts of Use Case 2.0
3.1 Use Cases
A use case is a sequence of actions a system performs that yields an observable result of value to a particular user. It's the smallest unit of activity that provides meaningful value .
Think of a use case as a goal that a user wants to achieve, not a list of features. Example goals:
  • "Borrow a book" (not "Scan barcode, update database...")
  • "Purchase a product" (not "Process payment, update inventory...")
3.2 Use Case Slices
A use case slice is the most important concept in Use Case 2.0. It represents one or more stories selected from a use case, forming a work item of clear value to the customer .
Use case slices are the bridge to Agile development - they become your backlog items, replacing or complementing traditional user stories.
Example: The "Borrow Book" use case can be sliced into:
Use Case Stories Slices
Borrow Book Borrow with success (Basic Flow) Slice A: Successful Borrow
Borrow Book Maximum borrow record reached Slice B: Borrow Failed (Max Books)
Borrow Book Borrower owes fine Slice B: Borrow Failed (Owes Fine)
Both failure stories can be grouped into a single slice "Borrow Failed" if that delivers value together .
3.3 Stories
Stories are the detailed descriptions of how a specific goal is achieved or how problems are handled. Each story traces through part of a use case's flow .
Stories fall into three categories:
  • Basic Flow Story - The simplest, most typical way to achieve the goal
  • Alternative Stories - Different ways to achieve the same goal
  • Exception Stories - Error conditions and problem handling
Example: From the "Withdraw Cash" use case:
  • Story A: "Withdraw $100 successfully with receipt" (Basic flow, standard amount)
  • Story B: "Withdraw $75 and get receipt" (Alternative flow, non-standard amount)
  • Story C: "Respond to invalid PIN" (Exception flow)
3.4 Scenarios and Paths
Each use case slice contains scenarios - the different paths a user might take:
  • Normal Path - The happy path, what usually happens
  • Alternative Path - Variations, different choices
  • Exception Path - Error handling, failures
4. Use Case 2.0 Development Process (STEPS)
The STEPS method (Seamless Technique Expressed in Prescribed Steps) provides a step-by-step approach to Use Case 2.0 :
Step 1: Form the Team
Identify the people who will participate in use case identification and management.
Step 2: Find Actors and Use Cases
Identify the system's actors (who uses it) and use cases (what goals they want to achieve).
Example: Library Management System
Actor Use Cases
Member Borrow Book, Return Book, Search Catalog
Librarian Borrow Book, Return Book, Manage Inventory, Manage Members
System Admin Configure System, Manage Backups
Step 3: Identify Use Case Stories
For each use case, capture the stories:
Use Case Stories
Borrow Book - Borrow with success (Basic flow)
- Max borrow record reached (Exception)
- Borrower owes fine (Exception)
Return Book - Return with success (Basic flow)
- Damaged book (Exception)
- Late return (Exception)
Step 4: Slice Up the Use Cases
Group stories into value-delivering slices:
Use Case Slice Stories Included
Borrow Book Borrow Success Basic flow story
Borrow Book Borrow Failed Max books reached + Owes fine
Return Book Return Success Basic flow story
Return Book Return With Penalty Late return + Damaged book
Step 5: Perform Release Planning
Decide which slices go into which releases/sprints. Prioritize by business value.
5. Visual Modeling with PlantUML
PlantUML is perfect for Use Case 2.0 because it's text-based, version-control friendly, and easy to update in Agile projects .
5.1 Basic Use Case Diagram Structure
@startuml
left to right direction
skinparam packageStyle rectangle
actor "User" as user
actor "Administrator" as admin
' Actor Generalization (Inheritance)
admin --|> user
rectangle "Library Management System" {
    usecase "Borrow Book" as UC1
    usecase "Return Book" as UC2
    usecase "Search Catalog" as UC3
    usecase "Manage Members" as UC4
    usecase "Configure System" as UC5
user --> UC1
user --> UC2
user --> UC3
admin --> UC4
admin --> UC5
@enduml
What this shows:
  • System boundary (rectangle)
  • Actors outside the system
  • Use cases inside
  • Actor generalization (Admin inherits User capabilities)
  • Associations (who can do what)
5.2 Include and Extend Relationships
«include» - Mandatory reuse. The base use case always calls the included use case .
«extend» - Optional, conditional behavior. Only triggers under specific conditions .
@startuml
actor "Member" as member
actor "External Validation System" as validation
rectangle "Advanced Library System" {
    usecase "Borrow Book" as borrow
    usecase "Return Book" as return
    usecase "Check Membership Status" as check
    usecase "Handle Fine Payment" as fine
    usecase "Log Suspicious Activity" as log
member --> borrow
member --> return
member --> fine
' Include: Both borrow and return MUST check membership
borrow .> check : <<include>>
return .> check : <<include>>
' Check membership calls external system
check --> validation
' Extend: Fine payment can extend borrow (optional, conditional)
fine .> borrow : <<extend>>
@enduml
Understanding the arrows:
  • A .> B : <<include>> = A always uses B
  • A .> B : <<extend>> = A may extend B in certain situations
5.3 Modeling Use Case Slices and Stories
Use Case 2.0 stories are often represented as extended use cases:
@startuml
rectangle "Library System" {
    usecase "Borrow Success" as success
    usecase "Borrow Failed (Max Books)" as maxBooks
    usecase "Borrow Failed (Owes Fine)" as owesFine
member --> borrow
' Stories as extend relationships
success .> borrow : <<extend>>
maxBooks .> borrow : <<extend>>
owesFine .> borrow : <<extend>>
@enduml
Note: The basic flow story is represented by the base use case itself. Alternative and exception stories are modeled as extends .
6. Complete Example: E-Commerce System
Let's build a complete Use Case 2.0 model for an e-commerce platform.
Step 1: Actors and Use Cases
Actor Use Cases
Customer Browse Products, Search Products, Add to Cart, Checkout, View Order History
Admin Manage Inventory, Manage Users, View Sales Reports
Payment Gateway Process Payment
Step 2: Use Case Diagram
@startuml
actor "Customer" as customer
actor "Admin" as admin
actor "Payment Gateway" as payment
rectangle "E-Commerce Platform" {
    usecase "Browse Products" as browse
    usecase "Search Products" as search
    usecase "Add to Cart" as addCart
    usecase "Checkout" as checkout
    usecase "View Order History" as history
    usecase "Manage Inventory" as inventory
    usecase "Process Payment" as processPay
    usecase "Validate Payment" as validatePay
    usecase "Refund Payment" as refund
customer --> browse
customer --> search
customer --> addCart
customer --> checkout
customer --> history
admin --> inventory
admin --> browse
admin --> search
' Checkout includes payment processing
checkout .> processPay : <<include>>
' Process payment uses validation
processPay .> validatePay : <<include>>
' Refund extends process payment (optional)
refund .> processPay : <<extend>>
' Payment gateway is external actor for processing
payment <-- processPay
@enduml
Step 3: Identify Stories for "Checkout"
Story Type Story Description
Basic Flow Customer successfully completes purchase with credit card
Alternative 1 Customer pays with PayPal
Alternative 2 Customer pays with gift card
Exception 1 Payment declined - insufficient funds
Exception 2 Payment declined - invalid card details
Exception 3 Inventory unavailable at checkout
Step 4: Slice the Checkout Use Case
Slice Name Stories Business Value
Checkout Success - Credit Card Basic flow (credit card) High - most common path
Checkout Success - PayPal Alternative 1 Medium - supports more customers
Checkout Success - Gift Card Alternative 2 Low - nice to have
Checkout Failed - Payment Exception 1, Exception 2 High - must handle errors gracefully
Checkout Failed - Inventory Exception 3 High - prevents overselling
Step 5: Diagram with Stories as Extends
@startuml
rectangle "E-Commerce Checkout" {
    usecase "Checkout - Credit Card Success" as ccSuccess
    usecase "Checkout - PayPal Success" as paypal
    usecase "Checkout - Gift Card Success" as gift
    usecase "Checkout - Payment Declined" as declined
    usecase "Checkout - Inventory Issue" as inventoryIssue
    usecase "Check Inventory" as checkInv
' Payment processing is mandatory
checkout .> checkInv : <<include>>
' Success stories
ccSuccess .> checkout : <<extend>>
paypal .> checkout : <<extend>>
gift .> checkout : <<extend>>
' Failure stories
declined .> checkout : <<extend>>
inventoryIssue .> checkout : <<extend>>
' External system
@enduml
7. Using Use Case 2.0 with Agile Backlogs
One of the biggest benefits of Use Case 2.0 is its natural fit with Scrum and Kanban backlogs .
Mapping Use Case Slices to Backlog Items
Epic: E-Commerce Checkout
Stories (Backlog Items):
🟢 Sprint 1: Checkout Success - Credit Card
   - Normal path: credit card payment
   - Acceptance tests: valid card, sufficient funds
🟢 Sprint 2: Checkout Success - PayPal
   - Alternative path: PayPal redirect
   - Acceptance tests: PayPal success flow
🟡 Sprint 3: Checkout Failed - Payment
   - Exception handling: declined, invalid
   - Acceptance tests: declined response handling
🔵 Sprint 4: Checkout Success - Gift Card
   - Alternative path: gift card entry
   - Acceptance tests: valid/invalid gift card
🔵 Sprint 5: Checkout Failed - Inventory
   - Exception handling: out of stock at checkout
   - Acceptance tests: inventory validation
Benefits for Agile Teams
  1. Better backlog grooming: Use case slices provide context that raw user stories lack
  2. Clearer testing: Each story maps directly to test cases
  3. Improved estimation: With clear boundaries, estimates become more accurate
  4. Rich requirements without heavy docs: Lightweight but comprehensive
8. Testing with Use Case 2.0
Use Case 2.0 excels at driving testing :
How Use Cases Drive Testing
Each story in a use case represents a test scenario:
Story Test Case
Basic flow: Credit card success Test: Valid card, valid amount, available funds → Success
Alternative: PayPal success Test: Redirect to PayPal, complete payment → Success
Exception: Insufficient funds Test: Card with insufficient funds → Decline message
Exception: Inventory issue Test: Item goes out of stock during checkout → Error
Key Benefit: You derive acceptance criteria directly from the use case stories, eliminating ambiguity .
9. Practical Tips for Beginners
Start Simple
  • Don't create all use cases upfront. Identify just enough to start development .
  • Use index cards or lightweight tools for initial stories .
Focus on Value
  • Ask: "What value does this use case deliver to the user?"
  • Prioritize slices by business value, not technical ease.
Adapt to Your Team
  • Small teams can use very lightweight narratives .
  • Larger, distributed teams may need more detailed documentation.
  • No one-size-fits-all - adapt to what works for you.
Slice for Delivery
  • Each slice should be completable within a sprint.
  • Slices should deliver observable value when complete.
  • Don't slice too small (loses value context) or too large (can't finish).
Use Visual Models
  • Diagrams communicate big picture quickly .
  • PlantUML keeps diagrams in version control.
  • Update diagrams as the system evolves, not as a one-time activity.
10. Summary: Why Use Case 2.0?
Use Case 2.0 combines the structured thinking of traditional use cases with the flexibility of Agile development.
Strength How Use Case 2.0 Delivers
Business Focus Use cases capture goals, not just features
Agile Ready Slices become backlog items
Testable Each story defines acceptance criteria
Scalable Works for small teams and large systems
Collaborative Stories are easy for stakeholders to understand
Visual Diagrams provide big-picture context
References
  • [1] Ivar Jacobson, Ian Spence, Brian Kerr. "Use-Case 2.0: The Hub of Software Development." ACM Digital Library.
  • [2] Visual Paradigm Guides. "Developing a New E-commerce Platform with Use Case 2.0."
  • [3] Ivar Jacobson International. "Use-Case 2.0 eLearning."
  • [4] Visual Paradigm. "STEPS Wizards Example: Use Case 2.0."
  • [5] Visual Paradigm Blog. "Bridging Requirements and Design: A Practical Guide to Use Case Modeling with UML and PlantUML."
