Agile Tutorial: How to Identify Business Goals
Whether you are developing a software system or an application, and whether it is large or small, it is essential that you understand the big picture. Without an understanding of the system as a whole it will be difficult to make correct decisions about what to include in the product and what to leave out of it. This can be done by creating a use case model that sums up the desired system and lets you understand scope and progress at a system level.
What is use case diagram?
A use case diagram is a visualization of use case model. In a use case model, the stakeholders that use the system and/or assists in the completion of goals are modeled as actors, and the ways that the system will be used to achieve these goals are modeled as use cases.
Identifying business goals
Perform the steps below to identify the goals of your scrum project and represent them in a use case model. You may try the steps interactively by visiting the interactive product tour.
  1. In the Scrum Process Canvas, click on the work item Identify Business Goals to open it.
  2. To perform the step, click on the action artifact Use Case Model.
  3. Draw a use case diagram to represent the actors (i.e. kind of product users) and use cases (i.e. the business goals to be achieved). A use case diagram is a visualization of use case model. In a use case model, the stakeholders that use the system and/or assists in the completion of goals are modeled as actors and the ways that the system will be used to achieve these goals are modeled as use cases.
  4. When you finish drawing, Go back to the work item page via the breadcrumb.
  5. This step has one more action artifact – Prioritized Use Cases. Click to open it.
  6. This shows an ETL Table that lists the use case you created in the diagram. Complete this table by entering the priority, size and complexity of the use cases. To describe a use case, click on the Description cell of the row of use case.
  7. Enter the description in the in the Description pane.
  8. Select the priority of use cases. Use cases are prioritized to deliver the greatest and most immediate business benefits early. Read the Instruction pane for details about the choices.
  9. Select the size of use case, which is a subjective rating of the effort required to support the use case.
  10. Select the complexity of use case, which is a subjective rating of the relative difficulty in supporting the use case.
  11. Repeatedly update the other use cases.
  12. Go back to the work item page via the breadcrumb.
  13. When you are done, click on Commit at the bottom right corner, and then select Complete from the popup menu.
