Practical AWS Diagram tutorial and exampes
Amazon Web Services (AWS) was launched in 2006, and has since become one of the one of the most popular cloud platforms currently available in the market. The AWS Cloud computing is increasing in a rapid manner from the past few years. It has come up with high-performance scalability, reliability, agility and responsibilities with certain design principles to run AWS on system efficiency. With this AWS Architecture diagram, one can easily understand and acquire clear knowledge about architecting, building and running applications on AWS technology.
Cloud computing - an overview
Advantages of cloud computing
  • Trade capital expense for variable expense – Instead of having to invest heavily in data centers and servers before you know how you’re going to use them, you can pay only when you consume computing resources, and pay only for how much you consume.
  • Benefit from massive economies of scale – By using cloud computing, you can achieve a lower variable cost than you can get on your own. Because usage from hundreds of thousands of customers is aggregated in the cloud, providers such as AWS can achieve higher economies of scale, which translates into lower pay as-you-go prices.
  • Stop guessing about capacity – Eliminate guessing on your infrastructure capacity needs. When you make a capacity decision prior to deploying an application, you often end up either sitting on expensive idle resources or dealing with limited capacity. With cloud computing, these problems go away. You can access as much or as little capacity as you need, and scale up and down as required with only a few minutes’ notice.
  • Increase speed and agility – In a cloud computing environment, new IT resources are only a click away, which means that you reduce the time to make those resources available to your developers from weeks to just minutes. This results in a dramatic increase in agility for the organization, since the cost and time it takes to experiment and develop is significantly lower.
  • Stop spending money running and maintaining data centers – Focus on projects that differentiate your business, not the infrastructure. Cloud computing lets you focus on your own customers, rather than on the heavy lifting of racking, stacking, and powering servers.
  • Go global in minutes – Easily deploy your application in multiple regions around the world with just a few clicks. This means you can provide lower latency and a better experience for your customers at minimal cost.
Why AWS – The 5 pillars
Creating a software system is a lot like constructing a building. If the foundation is not solid, structural problems can undermine the integrity and function of the building. When architecting technology solutions on Amazon Web Services (AWS), if you neglect the five pillars of operational excellence, security, reliability, performance efficiency, and cost optimization, it can become challenging to build a system that delivers on your expectations and requirements.
Amazon Web Services (AWS) - The five Pillars
  1. Operational Excellence – The operational excellence pillar includes the ability to run and monitor systems to deliver business value and to continually improve supporting processes and procedures. You can find prescriptive guidance on implementation in the Operational Excellence Pillar whitepaper.
  2. Security – The security pillar includes the ability to protect information, systems, and assets while delivering business value through risk assessments and mitigation strategies. You can find prescriptive guidance on implementation in the Security Pillar whitepaper.
  3. Reliability – The reliability pillar includes the ability of a system to recover from infrastructure or service disruptions, dynamically acquire computing resources to meet demand, and mitigate disruptions such as misconfigurations or transient network issues. You can find prescriptive guidance on implementation in the Reliability Pillar whitepaper.
  4. Performance Efficiency – The performance efficiency pillar includes the ability to use computing resources efficiently to meet system requirements and to maintain that efficiency as demand changes and technologies evolve. You can find prescriptive guidance on implementation in the Performance Efficiency Pillar whitepaper.
  5. Cost Optimization – The cost optimization pillar includes the ability to avoid or eliminate unneeded cost or suboptimal resources. You can find prescriptive guidance on implementation in the Cost Optimization Pillar whitepaper.
AWS architecture design tool
If you use Amazon Web Services (AWS), you will love our AWS Architecture diagram tool. Our AWS diagram tool provides you with full set of AWS icons to use in your AWS Architecture design. Besides, you can also connect those AWS shapes with traditional UML shapes like nodes, components and artifacts in UML deployment diagram for better representation of ideas. Now you don’t need to struggle with generic drawing tools for AWS architecture.
The best AWS diagramming tool
AWS diagram examples
You can make use of the free AWS Architecture diagram examples and templates as a starting point to create your own AWS Architecture diagrams. Here are some AWS diagram templates.
Expedia standard deployment architecture:
AWS diagram example - Expedia standard deployment architecture
TheSkyNet architecture:
AWS diagram example - theSkyNet
Game architecture:
AWS diagram example - Game architecture
How to create an AWS diagram?
Want to create your own AWS diagram for your IT solution?
Easy! Simply go through the three steps below to get started.
  1. Download Visual Paradigm here.
  2. Install and run Visual Paradigm.
  3. You are now opening a new project. Create an AWS architecture diagram by selecting Diagram > New from the main menu, and then selecting AWS diagram to continue.
    Create new AWS diagram
How to create AWS diagram online?
Visual Paradigm Online, our web-based diagramming software features an online AWS architecture design tool. If you want to draw AWS solely on the web, click here for details.
