TOGAF ADM Phase B: Business Architecture – A Comprehensive Guide
1. Overview & Purpose
Phase B of the TOGAF Architecture Development Method (ADM) focuses on the development of the Business Architecture. This phase establishes the fundamental organization of a business, detailing how processes, people, principles, and structures interrelate to achieve strategic objectives. It serves as the critical foundation for all subsequent architecture domains (Data, Application, and Technology). Without a clearly defined Business Architecture, technical solutions risk being misaligned with actual business needs, leading to wasted investment and operational friction.
Business Architecture answers the core question: How must the enterprise operate to meet its business goals and strategic drivers?
2. Core Objectives of Phase B
Phase B is designed to achieve two primary objectives:
  1. Develop the Target Business Architecture: Define how the enterprise must operate to achieve its business goals, respond to strategic drivers outlined in the Architecture Vision, address the Statement of Architecture Work, and resolve key stakeholder concerns.
  2. Identify Candidate Architecture Roadmap Components: Analyze the gaps between the current (Baseline) and future (Target) Business Architectures to identify initial work packages, capabilities, or initiatives that will transition the enterprise toward its target state.
3. Foundational Concepts for Beginners
To navigate Phase B effectively, you must understand several core architectural concepts:
Concept Definition Why It Matters
Business Architecture A holistic, multi-dimensional view of business capabilities, end-to-end value delivery, information, and organizational structure, along with their relationships to strategy, products, policies, and stakeholders. Provides the strategic blueprint that guides all technical and operational design decisions.
Baseline Architecture The documented current state of the business, including existing processes, capabilities, organizational units, and value streams. Establishes a factual starting point. You cannot plan a journey without knowing your origin.
Target Architecture The documented future state that the business aims to achieve to meet strategic objectives. Defines the destination and serves as the benchmark for all architecture work.
Business Capability A specific ability that a business possesses or exchanges to achieve a purpose. It is what the business does, independent of how or who does it. Enables stable, reusable planning that survives organizational restructuring or system changes.
Value Stream An end-to-end collection of value-adding activities that create an overall result for a customer, stakeholder, or end user. Reveals why capabilities are needed and highlights inefficiencies or bottlenecks from a customer perspective.
Organization Map A visual representation of business units, third parties, and partners, showing who owns or participates in capabilities and value streams. Clarifies accountability, identifies stakeholders to engage, and maps cross-functional dependencies.
4. The Step-by-Step Approach to Phase B
Phase B follows a structured, repeatable approach. Below is a practical breakdown of how to execute it:
Step 1: Validate Scope & Strategic Context
  • Review the Architecture Vision from Phase A to confirm the scope, business goals, strategic drivers, and key stakeholder concerns.
  • Ensure the business strategy is clearly documented. If not, conduct preliminary research to define mission, vision, and success metrics before proceeding.
Step 2: Establish the Baseline Description
  • Leverage existing architecture documentation, process maps, or organizational charts if available.
  • If no documentation exists, gather information through stakeholder interviews, workshops, and system audits to document the current state accurately.
Step 3: Apply Core Business Architecture Techniques
TOGAF recommends four primary techniques to develop both Baseline and Target architectures:
A. Applying Business Capabilities
  • Create a Business Capability Map that lists all core abilities of the enterprise (e.g., "Customer Acquisition," "Order Fulfillment," "Risk Management").
  • Map each capability to organizational units, value streams, information systems, and strategic plans.
  • Benefit: Provides a stable, technology-agnostic view of the business that remains valid even when departments or software change.
B. Applying Value Streams
  • Identify end-to-end sequences of activities that deliver value to stakeholders (e.g., "Prospect to Customer," "Claim to Settlement").
  • Use heat mapping to color-code value stream stages based on performance, pain points, or strategic importance.
  • Map value stream stages to business capabilities to identify where gaps or redundancies exist.
C. Applying the Organization Map
  • Diagram the enterprise's internal business units, external partners, suppliers, and customers.
  • Link each entity to the capabilities they own and the value streams they participate in.
  • Benefit: Reveals cross-functional dependencies, clarifies ownership, and identifies which teams must be involved in architecture decisions.
D. Applying Business Modeling
  • Supplement capability and value stream maps with detailed models such as:
    • Activity/Business Process Models (workflow diagrams)
    • Use-Case Models (system-user interactions)
    • Class Models (domain entity relationships)
  • These can be standardized using frameworks like UML or industry-specific notations.
Step 4: Perform Gap Analysis
  • Compare the Baseline and Target Business Architectures across capabilities, value streams, and organizational structures.
  • Identify deliberately omitted items, accidentally overlooked functions, or newly required capabilities.
  • Document gaps with clear justifications: Are they to be eliminated, improved, or newly developed?
Step 5: Identify Roadmap Components
  • Translate identified gaps into actionable initiatives.
  • Group related changes into logical work packages.
  • Feed these candidate components into Phase E (Opportunities & Solutions) for sequencing and planning.
5. Practical Examples for Beginners
Example 1: Retail Company Transitioning to Omnichannel
Business Goal: Provide seamless customer experience across online, mobile, and physical stores.
  • Capability Focus: Order Fulfillment, Inventory Management, Customer Service
  • Baseline State: Fulfillment is siloed. Online orders ship from a separate warehouse; store associates cannot access online inventory data.
  • Target State: Unified Order Fulfillment capability enabling ship-from-store, buy-online-pickup-in-store (BOPIS), and real-time inventory visibility.
  • Value Stream: Customer Purchase Journey (Browse → Add to Cart → Checkout → Fulfill → Return). Heat mapping reveals the "Fulfill" stage as a major bottleneck.
  • Organization Map: E-commerce team, Store Operations, Logistics Partner, IT Support. Mapping shows unclear ownership of inventory data accuracy.
  • Outcome: Phase B defines the target capability model, identifies the need for a shared data service, and flags organizational realignment as a roadmap component.
Example 2: Financial Institution Streamlining Loan Processing
Business Goal: Reduce loan approval time from 14 days to 3 days while maintaining compliance.
  • Capability Focus: Credit Assessment, Document Verification, Regulatory Compliance, Loan Disbursement
  • Baseline State: Manual document collection, sequential department handoffs, duplicate data entry.
  • Target State: Automated document ingestion, parallel processing workflows, integrated compliance checking.
  • Value Stream: Loan Application to Disbursement. Heat mapping highlights excessive wait times between "Underwriting" and "Compliance Review."
  • Organization Map: Sales Branches, Underwriting Dept, Compliance Office, Core Banking System Team.
  • Outcome: Gap analysis reveals missing Automated Document Processing capability. Roadmap component: Implement OCR/AI verification service and redesign handoff protocols.
6. Leveraging the Architecture Repository
Phase B should not start from scratch. Effective architects tap into the organization's Architecture Repository to accelerate delivery:
  • Industry Reference Models: Adopt proven capability maps or process models specific to your sector (e.g., retail, healthcare, telecom).
  • Enterprise-Specific Views: Reuse existing capability maps, value stream diagrams, or organization maps from past initiatives.
  • Enterprise Building Blocks: Pull reusable process components, business rules, role definitions, or job descriptions.
  • Applicable Standards: Incorporate regulatory frameworks, data privacy mandates, or industry best practices that constrain or guide business design.
7. Key Deliverables & Outputs
Upon completion of Phase B, the following artifacts are typically produced or updated:
  • Architecture Definition Document (Business Architecture Section): Contains the detailed Baseline and Target Business Architecture models.
  • Business Capability Map & Value Stream Diagrams: Visual representations of current and future states.
  • Organization Map: Updated chart showing ownership and participation across capabilities/value streams.
  • Gap Analysis Report: Documented differences between Baseline and Target, with recommendations.
  • Candidate Architecture Roadmap Components: Initial list of projects, initiatives, or capability increments derived from gaps.
  • Updated Architecture Requirements Specification: Quantitative business requirements that will guide Phases C and D.
8. Best Practices for Success
  1. Start with Business Architecture First: It is a prerequisite for Data, Application, and Technology Architectures. Skipping it leads to technology-driven solutions that miss business value.
  2. Align Strictly with Phase A: Every capability, value stream, and organizational change must trace back to the Architecture Vision and Statement of Architecture Work.
  3. Keep Capabilities Technology-Agnostic: Define what the business does, not which system does it. This ensures longevity and flexibility.
  4. Engage Stakeholders Early: Use the Organization Map to identify who needs to be involved. Secure buy-in by demonstrating how changes improve their value stream stages.
  5. Iterate, Don't Perfect: Business Architecture evolves. Deliver a "good enough" baseline and target to enable downstream architecture work, then refine through ADM cycles.
  6. Reuse Before Creating: Always check the Architecture Repository for existing models, industry patterns, or regulatory templates before building new ones.
9. Conclusion
TOGAF ADM Phase B: Business Architecture is the strategic anchor of the entire architecture development cycle. By systematically mapping capabilities, analyzing value streams, clarifying organizational responsibilities, and rigorously comparing current and future states, architects ensure that technology investments directly serve business outcomes. When executed correctly, Phase B produces a clear, stakeholder-aligned blueprint that seamlessly guides the development of Information Systems and Technology Architectures in subsequent phases, ultimately driving measurable business transformation and sustainable competitive advantage.
Reference
  1. TOGAF ADM Tools: Comprehensive overview of Visual Paradigm's TOGAF Architecture Development Method (ADM) tools, featuring the ADM Process Navigator, guided step-by-step workflows, form-filling capabilities, deliverable composer, auto-versioning, shape/color legends, model extractor for element reuse, and architecture repository management. Supports all TOGAF ADM phases from Preliminary through Phase H with actionable instructions and sample deliverables.
  2. Step-by-Step Enterprise Architecture Tutorial with TOGAF ADM: Detailed hands-on tutorial demonstrating how to execute TOGAF ADM phases using Visual Paradigm. Walks through the Preliminary Phase with practical examples: scoping impacted organizations using ArchiMate diagrams, performing architecture maturity assessments with radar charts, completing activity steps, and generating/archiving TOGAF deliverables in the Architecture Repository.
  3. TOGAF ADM Software: Product page highlighting Visual Paradigm's revolutionary TOGAF ADM software designed for EA teams. Features visual process maps for navigating ADM phases, integrated ArchiMate modeling, radar charts for maturity analysis, breakdown structures, scheduling tools, task management, form-based data entry, incremental artifact development, and one-click TOGAF deliverable generation with customizable report editor.
  4. TOGAF Software for Enterprise Architecture: In-depth guide explaining why TOGAF projects fail and how Visual Paradigm addresses common challenges. Compares traditional EA tools vs. Visual Paradigm's Guide-Through and Just-in-Time process approaches. Details benefits: structured ADM phases with embedded instructions, progress indicators, incremental analysis/diagramming, automatic data transformation, task assignment, and seamless EA/PM/agile integration.
  5. TOGAF ADM Tool for Enterprise Architecture Tutorial: Step-by-step tutorial (published May 4, 2018; 78,537 views) demonstrating Visual Paradigm's TOGAF ADM capabilities. Covers project setup, opening the ADM navigator, executing Preliminary Phase activities (scoping organizations, maturity assessment), using ArchiMate diagrams and forms, completing steps, generating deliverables, and managing the Architecture Repository. Includes sample data tables and diagram examples.
  6. Step-by-Step Enterprise Architecture Tutorial: TOGAF ADM phases, Visual Paradigm's guided process, ArchiMate modeling, deliverable generation, and Architecture Repository usage.
  7. TOGAF ADM and Architecture Content Framework: Technical guide explaining the relationship between TOGAF ADM and the Architecture Content Framework. Defines key concepts: deliverables (contractually specified outputs), artifacts (catalogs/matrices/diagrams), and building blocks (reusable components). Details the content metamodel for describing architectural elements and their relationships. Emphasizes using the Content Framework as a companion to ADM for structured input/output management.
  8. Understanding the Difference Between TOGAF and ADM: Educational article (October 4, 2024) clarifying distinctions between TOGAF (the comprehensive framework) and ADM (the core methodology within TOGAF). Compares scope, functionality, components, phases, focus areas, governance coverage, use cases, flexibility, documentation requirements, and target audiences via detailed comparison table. Includes guidance on leveraging Visual Paradigm's TOGAF ADM Guide-Through tool for implementation.
  9. The Evolution of TOGAF 10: Empowering Enterprise Architecture in the Age of Agility: Insightful article (August 1, 2024) on TOGAF 10's enhancements for agile environments. Highlights modular structure for selective adoption, streamlined documentation, continuous evolution capabilities, and stronger IT-business alignment. Discusses how Visual Paradigm's TOGAF Guide-Through tool bridges framework theory and practical implementation with guided workflows, collaborative modeling, automated documentation, and ADM integration.
