How to Customize SysML Requirement Types?
When you need to record system requirements, both functional and non-functional, requirement modeling will be helpful. Through requirement modeling, requirements are recorded and presented visually as boxes, with a name that summarize the requirement and a set of attributes that define the requirement. The default requirement 'box' allows specifying general attributes like ID, source, kind, verify method, risk and status. You may, however, define your own requirement types that contain attributes related to your domain.
February 4, 2016
PDF Download
  1. Create a new project by selecting Project > New from the application toolbar.
  2. In the New Project window, enter Tutorial as the project name and click Create Blank Project.
  3. We will create several requirements in this tutorial. Let's create a requirement diagram first. To create a requirement diagram, select Diagram > New from the application toolbar.
  4. In the New Diagram window, select Requirement Diagram and click Next.
    New requirement diagram
  5. Enter Login as the diagram name and click OK.
    Naming requirement diagram
  6. On the left side of the diagram, you can see the diagram toolbar, where you can select a tool like a Requirement, a Model, or a Test Case and click on the diagram to create a shape. Normally, you would use the Requirement tool to create requirements. But in this tutorial, we will define our own types first. Select Window > Configuration > Configure Requirements... from the application toolbar.
  7. We will create two requirement types:
    Type Description
    Screen A type of requirement that consists of properties related to a screen design.
    Checking A type of requirement that consists of rules for validating input and the proper response to bad input.
    Create the Screen type first. Click Add at the bottom left of the Configure Requirements window. Then, enter Screen as the name.
    New a requirement type
  8. What makes the Screen type meaningful are its unique attributes (i.e., properties). For the Screen type, the following attributes are needed:
    Attribute Type Description
    description Text A description of the screen being documented.
    screen-id Text A unique and internal value for identifying the screen being documented.
    allow-reset Enumeration Determines whether there is a "Reset" button for clearing fields on the screen.
    allow-cancel Enumeration Determines whether there is a "Cancel" button to close the screen without proceeding.
    We need to define these properties. Click Add on the right side of the dialog box and select Text Attribute from the popup menu.
    Add a text attribute
  9. Enter description as the name. Repeatedly create the remaining properties. Make sure you have chosen Enumeration as the type for allow-reset and allow-cancel.
    Properties added
  10. The third attribute, "allow-reset," is an enumeration attribute that enables the selection of "yes" or "no." Select the attribute and click Edit Enumeration....
    Edit enumerations
  11. In the Edit Enumeration window, click Add and enter yes. Click Add again and enter no. This creates the two allowed values, "yes" or "no," for this attribute. Click OK to go back to the requirement configuration.
    Add enumeration values
  12. Similarly, add the enumeration values yes and no for the allow-cancel attribute.
  13. All four attributes have been added. Besides defining requirement attributes, you can also set formatting properties like fill, line, and font styles. These settings will affect how this type of requirement will look in a diagram. Let's try setting a different fill color. Click the ... button for Fill.
    Configure fill color
  14. In the Format Fill window, select yellow and click OK.
    Selecting a color
  15. This ends the configuration of the Screen type. Apply the same technique to create another requirement type, Checking. Here is a list of its attributes:
    description Text A description of the checking that needs to be performed.
    policy Enumeration Determines the action to take when bad input is detected upon checking. You may allow the user to try again or just cancel the action immediately.
    allowed-attempts Integer The number of attempts a user can make.
  16. Add the enumeration values cancel action for invalid entry and allow re-try for the policy attribute. In most checks, you should allow the user to try again. Therefore, select "allow re-try" and check Default value at the bottom. This will set allow re-try as the default value, which will be automatically selected when you create a <<Checking>> requirement.
    Requirement types created
  17. The requirement types are now configured. Click OK to return to the requirements configuration. Click OK again to confirm all the changes and return to the diagram.
  18. Now for the final attribute, allowed attempts. This is an attribute that requires a numeric input. Therefore, click Add and select Integer Attribute. Enter allowed attempts as the name.
    Select default value
  19. You can now create requirements with the new types. In the diagram toolbar, click on the Requirement tool and select Screen.
    Choose screen requirement type
  20. Click on the diagram to create a requirement. Name it Login Page. You will get a requirement like this:
    Requirement created
  21. Double-click on the description attribute and enter Provide a page for the user to log in to the system as the description. Similarly, double-click on screen-id and enter UI-001.
    Property entered
  22. Remember that allow-reset and allow-cancel are enumeration attributes. If you double-click on allow-reset, you will see that the value is restricted to either "yes" or "no," as defined. Select no for allow-reset and yes for allow-cancel.
    Selecting enumeration value
  23. Now, use the Checking type to specify a requirement for validating form input. Click on the Screen requirement type in the diagram toolbar and select Checking. Click on the diagram to create a requirement. Name it Form Field Checking.
    Requirement created
  24. Double-click on the description attribute and enter When submitted, warn the user if either or both the user name and password fields are empty.
    Properties filled
  25. It is fine to let the user re-enter the correct email address. Therefore, just keep the policy as allow re-try. Leave allowed-attempts empty to indicate that there is no restriction on the number of attempts.
  26. Create another <<Checking>> requirement named Login Checking. Set the description to When submitted, verify and disallow invalid login. and the policy to cancel action for invalid entry. Finally, you should have a diagram like this:
    Requirement diagram finished
