How to Bridge the Flows between Parent and Sub-Diagrams?
When modeling complex systems, we often use the sub-diagram to elaborate a particular elements in details. This helps to keep our design clean and context sensitive. However, in previous versions, sub-diagram didn't explain how the flows were associated between parent element and the child diagram. In Visual Paradigm, you can now display the in-flow and out-flow element in sub-diagram in certain situations, which helps you to identify the flows between diagrams.
January 13, 2015
PDF Download
In version 12.0, the elements for the incoming and outgoing flows are automatically pulled into the sub-diagram when:
  1. Modeling the behavior of an action in UML Activity Diagram
    01 define behavior
  2. Modeling the detail of a submachine state in State Diagram
    02 create submachine
  3. Modeling the detail of a sub-process in Business Process Diagram
    process
  4. Decomposing the process in a Data Flow Diagram
    04 decompose dfd process
Once the sub-diagram is created and the incoming and outgoing flows are pulled into the sub-diagram, you can then start modeling the sub-diagram from the incoming flow and end with the outgoing flow.
05 model with in out flow
To turn on the in-flow and out-flow indicator, right-click on the blank area of the diagram and select Presentation Options > Show In/Out Flows.
06 turn on in flow flow
Once the in-flow and out-flow indicators are shown, you can navigate to the parent diagram by double-clicking on it.
diagram
Watch This Tutorial on YouTube
