How to Visualize Model Dependencies with Analysis Diagram?
Discover consequence of changes before modification by analysis diagram. The "Software impact analysis with analysis diagram" shows how to perform use analysis diagram to discover and visualize all related elements, relationships and views of UML class.
September 16, 2009
PDF Download
To perform impact analysis with an analysis diagram:
Using an Analysis Diagram
  1. Download Department-Store.vpp. You can also find this file at the bottom of this tutorial, under the Resources section.
  2. Open the downloaded project file in Visual Paradigm.
  3. Open the diagram Sales Order.
  4. Let's analyze the Report class. Right-click on the Report class and select Related Elements > Analysis.
    analysis
  5. The Analysis window is shown. Let's create a new analysis diagram with the default name.
    analysis dialog
  6. You can specify what information will be included in the analysis diagram, including Transitor, Reference, Parent-child relationship, Sub-diagram, Relationship, <<Used>> dependency, and the View of the model.
    analysis option
    • Transitor: Transit from and to of the selected model.
    • Reference: Reference item of the selected model.
    • Parent-child: Parent and child relationship involved by the selected model.
    • Sub-diagram: Sub-diagrams under the selected model.
    • Relationship: Other elements related to the selected model.
    • Used: Used dependency involved by the selected model.
    • View: Diagrams which contain the selected model.
    • Composited model properties: .
  7. With Composited model properties checked, the resulting diagram will be very big. To keep things simple, let's uncheck it.
  8. Keep the other options selected and click OK to create an analysis diagram. Here is the analysis diagram generated.
    analysis diagram
  9. The View represents the diagram containing the Report class.
    view
  10. You can right-click on the View shape and select Open View, or use the Open View resource icon to open the diagram.
    open view
  11. The Model shape represents the element which is related to the Report class. For example, the Product class is related to Report with an association, and the StoreReport class is related to Report with generalization.
    relationship
  12. You can always right-click on the shape and select Select in tree, or use the Select in Tree resource icon to locate the element in Model Explorer.
    select in tree
  13. The items in the analysis diagram can be grouped together through the Group By option in the Property pane. Let's group the Relationship and View in the diagram.
    group
  14. You can further analyze the elements by clicking the Analyze resource icon, and then select the criteria you would like to analyze.
    re-analyse
