How to Expand a BPMN Sub-Process?
Sub-process is a standard BPMN notation that can be used to represent an activity within a business process. In this tutorial, we will take a look at some of the key actions you can perform on a sub-process.
May 26, 2010
PDF Download
What is a BPMN Sub-Process?
A sub-process is an activity in BPMN that represents a collection of related activities within a larger business process. It allows you to break down a complex process into smaller, more manageable parts that can be further detailed, analyzed, and optimized. Sub-processes can be used to represent both sequential and parallel flows of activities.
There are two main types of sub-processes: Embedded and Reusable.
  • Embedded sub-process: An embedded sub-process is defined and used within a single, larger process. It is represented by a rectangle with a thick border and is placed inside the main process. It has its own set of activities, events, and gateways that describe its internal flow.
  • Reusable sub-process: A reusable sub-process can be used in multiple processes. It is represented by a rectangle with a thin border and is defined outside of the main process. Like an embedded sub-process, it has its own set of activities, events, and gateways.
Benefits of Using Sub-Processes
Sub-processes offer several advantages, including:
  1. Clarity and simplicity: By breaking down a complex process into smaller parts, sub-processes make it easier to understand, follow, and communicate. They also help to eliminate redundancy and ambiguity.
  2. Reusability: Reusable sub-processes can save time and effort by allowing you to reuse the same process logic in different parts of a process or across multiple processes. This also helps to ensure consistency and standardization.
  3. Optimization: Sub-processes can be individually analyzed and optimized for performance and efficiency, leading to better outcomes and lower costs.
  4. Collaboration: Sub-processes can be assigned to different teams or individuals for implementation, promoting collaboration and accountability.
How to Model with Sub-processes
  1. Create a business process diagram with a start event and a task named Announce Proposal. Connect them with a sequence flow.
    Simple business process diagram
  2. You can create a sub-process using the Resource Catalog. Move your mouse pointer over the Announce Proposal task.
    Mouse over task
  3. Press and drag the Resource Catalog icon (at the top right of the shape) to an empty space on the diagram.
    Using Resource Catalog
  4. Release the mouse button and select Sequence Flow > Sub-Process from the Resource Catalog.
    Select sub-process
  5. Enter Collect Opinion as the name of the sub-process and press Enter to confirm.
    Sub-process created
Creating a Deeper Process Layer
Both tasks and sub-processes are activities in BPMN. However, a sub-process allows you to define a more detailed level of process logic in a separate sub-process diagram. Let's see how this works.
  1. Click the plus icon in the Collect Opinion sub-process and select New Business Process Diagram from the popup menu.
    Expand sub-process
    A new business process diagram will be created and opened. It contains a start and end event, which are used to connect the process flow from the parent diagram to the flow in this new diagram.
    Sub-process diagram created
  2. Create three tasks, Receive E-mail, Give General Reply, and Forward to Responsible Person, between the start and end events as shown below.
  3. Now, return to the parent diagram by clicking on the shortcut in the breadcrumb trail.
    Back to parent diagram
  4. You can optionally display the content of the sub-process as a preview within the sub-process shape. Click the plus icon in the Collect Opinion sub-process and select Expand Sub-Process Preview from the popup menu.
    Expand sub-process
    You will see a preview of the sub-process content. If the preview is too small or large, you can resize the sub-process shape, and the preview will automatically adjust to fit.
    Preview shown
Creating a Sub-Process Diagram from Existing Tasks
You can also group several flow objects in a business process diagram into a sub-process. Let's try it out.
  1. Draw a new business process diagram with a start event, an end event, and three tasks: Announce Proposal, Receive Email, and Forward to Responsible Person.
    Business process diagram
  2. Select the three tasks.
    Select tasks
  3. Right-click on the selected tasks and choose Form Separate Diagram Sub-Process from the context menu.
    Forming sub process diagram
    A new sub-process diagram will be created, and the three selected tasks will be moved into it.
    New sub process diagram formed
    If you had selected Form Same Diagram Sub-Process instead, a new sub-process shape would have been created in the same diagram, containing the three tasks, without creating a new business process diagram.
